Heating Resistor Failed :(
connellbost
Re: Heating Resistor Failed :(
Post by connellbost »
Still after all this still not heating past 122 degrees. Resitance on thermistor and heat cartridge checked. Within normal range. What else?
Post by Xenocrates »
First, can you post a copy of your config.g here so I can take a quick look at it and check things. Secondly, if you have a multi-meter could you check the voltage getting to the heater cartridge for me? Thirdly, any pictures or additional data about the problem and your setup can help. If we can get pictures of the electronics bay of your printer, and the hotend assembly, that would be helpful.
connellbost
Using Craftware
Question: Other alternatives other than Matter or Astrproprint? Love Astroprint for remote slicing, but has it's disadvantages for making rafts, etc. How is craftware and how is it configured for the rostock?
