Hey all
I have recently upgraded my Max V2, and have been trying to get it calibrated properly. Feels like I am getting there, but have run into a layer shift problem that I can't resolve. I think it may be the belt tension, but can't quite figure this one out. Hoping the experts can weigh in.
I can print a cube, and it turns out perfect. I have been trying to print this new part (quadcopter battery stop), since it small but more complicated. Have managed to minimize stringing through retract settings, but am experiencing shifting - very noticeable where layers move from totally solid to those with holes, and vice-versa. Photo attached.
[img]http://i.imgur.com/MeB0sdl.jpg[/img]
							Layer shifting
Layer shifting
Rostock Max V2. E3D V6 Hotend. E3D Titan Extruder. TrickLaser Carbon Fiber 300mm Arms. TrickLaser MaxMetal Platform. TrickLaser Trick Trucks. TrickLaser Heat Spreader. TrickLaser LED Light Ring. MeanWell SP-500-24. Simplify3D.
				IMBoring25
Re: Layer shifting
I wouldn't call that a layer shift.  It looks like you're underextruding on small-cross-section areas (or overextruding the rest of the time).
The v6 typically likes short, slow retraction (my usual setting is 2mm at 10mm/s). It's a little counterintuitive, but I got dramatically less-stringy prints and more consistent results with slower retraction. YMMV. I'm not familiar with S3D...Does it have a setting for differential settings for retract and unretract and are you using them?
Re: Layer shifting
Thanks IM. S3D does have those settings, and I made the adjustments. It helped, but it was still shifting. The image doesn't really show it well, but there was a definite shift.
Alas, it turns out that it was a mechanical issue. One of my Trick Trucks was too tight. After adjusting all of them and checking belt tension again, the printer seems to be working great again.
