Easier way to sand the Rostock arms
I have found that if I stack seven emery boards they are almost perfect width to sand the Rostock arms.
After stacking the seven and squeezing them between the ends of the arms then sand and sand and sand the
final result is an arm with a virtually perfect space to fit the joints without slop. The emery boards I used were
from Walmart, Company name Trim in a pack of 20. 00348 is a part number in the top right of the package.
Carl
Carl
Re: Easier way to sand the Rostock arms
I been trying to find a better way to do this also. I was thinking along the same lines.
- foshon
Eaglezsoar wrote:I have found that if I stack seven emery boards they are almost perfect width to sand the Rostock arms.
Carl
Carl I do believe I love you!!
Purple = sarcasm
Let's take it easy, this is a public board.foshon wrote:Eaglezsoar wrote:I have found that if I stack seven emery boards they are almost perfect width to sand the Rostock arms.
Carl
- foshon
Eaglezsoar wrote:Let's take it easy, this is a public board.foshon wrote:Eaglezsoar wrote:I have found that if I stack seven emery boards they are almost perfect width to sand the Rostock arms.
Carl
Like a brother man, like a brother.
Purple = sarcasm
Brother it be, brother. Tell Mom I said Hey!
Carl
Carl
- foshon
Eaglezsoar wrote:Brother it be, brother. Tell Mom I said Hey!
Carl
Will do, pot roast tonight, you in?
Purple = sarcasm
That tip is worth a few minutes of searching and a couple of dollars at wally world. Thank you.
MOM!!!!!! Meatloaf!!!!!!!foshon wrote:Will do, pot roast tonight, you in?Eaglezsoar wrote:Brother it be, brother. Tell Mom I said Hey!
Carl
What does she even do in there?
Mom makes Pot Roast and Meatloaf.
She also takes care of Foshon who creates 3d printed Pot Roast and Meatloaf servers.
You guys are goofy. It's great.
What's great, the Pot Roast, the Meat Loaf or the sanding idea?
All of the above ^^^
Sanding meat loaf with a pot roast sounds delicious.
edit: I can't be the only one who read it that way...
Eaglezsoar wrote:What's great, the Pot Roast, the Meat Loaf or the sanding idea?
- foshon
lordbinky wrote:Sanding meat loaf with a pot roast sounds delicious.
What grit do you recommend, and wet or dry?
Purple = sarcasm
This requires testing and datasheets. My intuition is that because meatloaf needs ketchup, wet. I think you have to add the grits to the meatloaf though.foshon wrote:lordbinky wrote:Sanding meat loaf with a pot roast sounds delicious.
- foshon
lordbinky wrote:This requires testing and datasheets. My intuition is that because meatloaf needs ketchup, wet. I think you have to add the grits to the meatloaf though.foshon wrote:lordbinky wrote:Sanding meat loaf with a pot roast sounds delicious.
Sounds tasty Chef lordbinky! As well as smooth!
Purple = sarcasm
You guys are all nuts!
This is true, and this thread has been seriously derailed in the best possible way
And to think I helped to derail my own thread!
