[img]http://www.perrydice.com/images/day1.jpg[/img]
A few more things to print, and then it's time to get buzy!
[img]http://www.perrydice.com/images/day1-midnite.jpg[/img]
Midnite is wondering what the holdup is?!?
I picked up these guys. (I don't have them together properly yet. I wanted to get a picture for you.)3D-Print wrote:Awesome! Will follow along. Like the belt tensioner's. I love them.
What are your plans for extruder steppers?
; Configuration file for Rostock with Diamond/Duet from Perrydice
; ***Hardware Configuration for this build***
; Duet 0.85 controller/Duex4/PanelDue/7"Touchscreen
; Diamond Hotend
; 3 non-geared extruder motors
; FSR Z-Probes under heated bed
; Stock SeemeCNC arms (old 269 mm type)
; Stock Seemecnc cheapskates (new injection molded)
; Stock SeemeCNC heated bed with Boroglass
; ~260-270 mm printable area (280 is too big with old stock SeemeCNC arms on new cheapskates)
; Communication and general
M111 S0 ; Debug off
M550 PPerrydice_Delta ; Machine name and Netbios name (can be anything you like)
M551 Ppassword ; Machine password (used for FTP and web interface access)
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
;*** Adjust the IP address and gateway in the following 2 lines to suit your network
M552 P0.0.0.0 ; IP address (0 = use DHCP)
M554 P192.168.1.1 ; Gateway
M553 P255.255.255.0 ; Netmask
M555 P2 ; Set output to look like Marlin
M575 P1 B57600 S1 ; Comms parameters for PanelDue
;Default starting parameters
G21 ; Work in millimetres
G90 ; Send absolute coordinates...
M83 ; ...but relative extruder moves
;Fans (PEEK fan conected to ConstantON-Layer fan connected to Fan 0)
;M106 I1 ; Invert fans
M106 P0 S0 ; Turn off Fan 0
M106 P1 S0 ; Turn off Fan 1
; Axis and motor configuration
M569 P0 S0 ; Drive 0 goes backwards
M569 P1 S1 ; Drive 1 goes forwards
M569 P2 S0 ; Drive 2 goes backwards
M569 P3 S0 ; EDrive 0 goes backwards
M569 P4 S0 ; EDrive 1 goes forwards
M569 P5 S0 ; EDrive 2 goes forwards
M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
M665 R140.95 L269 B130 H396 ; set delta radius, diagonal rod length, printable radius and homed height
M666 X-0.02 Y-0.02 Z0.04 ; put your endstop adjustments here, or let auto calibration find them
M92 X80 Y80 Z80 ; Set axis steps/mm
M906 X1000 Y1000 Z1000 E1000 ; Set motor currents (mA)
M906 I80 : Set motor Idle current
M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
M566 X1300 Y1300 Z1300 E1300 ; Maximum instant speed changes mm/minute
M207 S5.0 F2400 : 5mm retraction at 2400mm.min (40mm/sec) for the all three extruders to prevent the Diamond Head ooze!
;PID Settings
;For manual adjustments: if it overshoots a lot and oscillates, either the integral gain needs to be increased or all gains should be reduced. Too much overshoot? Increase D, decrease P.
;Response too damped? Increase P. Ramps up quickly to a value below target temperature (0-160 fast) and then slows down as it approaches target (160-170 slow, 170-180 really slow, etc)
;temperature? Try increasing the I constant.
M301 H0 P24 I0.80 D105 T0.50 S1.0 ; PID settings for Print Bed (-P means bang bang setting and not PID)
M301 H1 P08 I0.20 D109 T0.50 S1.0 ; PID settings for Heater 1 (Diamond Hot)
; Thermistors
;*** If you have a Duet board stickered "4.7K", change R1000 to R4700 to the following M305 commands
M305 P0 T100000 B4286 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 B4375 R4700 H30 L0 ; Put your own H and/or L values here to set the 1st nozzle thermistor ADC correction
M570 S280 ; Hot end may be a little slow to heat up so allow it 280 seconds
; Tool definitions
M92 E146.27:146.27:146.27 ; Set steps/mm for extruders (not geared)
M563 P0 D0:1:2 H1 ; Define tool 0
G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
M567 P0 E1.0:0.0:0.0 ; Set mixing to extruder 1 at 100%
M568 P0 S1 ; Turn on mixing S= (1 = on, 0=off)
M563 P1 D0:1:2 H1 ; Define tool 1
G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
M567 P1 E0.0:1.0:0.0 ; Set mixing to extruder 2 at 100%
M568 P1 S1 ; Turn on mixingS= (1 = on, 0=off)
M563 P2 D0:1:2 H1 ; Define tool 2
G10 P2 S0 R0 ; Set tool 2 operating and standby temperatures
M567 P2 E0.0:0.0:1.0 ; Set mixing to extruder 3 at 100%
M568 P2 S1 ; Turn on mixing S= (1 = on, 0=off)
; Z probe and compensation definition
M558 P4 X0 Y0 Z0 H3 ; Z probe is a switch and is not used for homing any axes
G31 X0 Y0 Z-.05 P500 ; Set the zprobe height and threshold (put your own values here)
;*** If you are using axis compensation, put the figures in the following command
M556 S78 X0 Y0 Z0 ; Axis compensation here
M208 S1 Z-0.2 ; set minimum Z
;Select tool and begin
T0 ; select first hot end
