Zero Lash Straps from tricklaser problem
duvdev
Post by duvdev »
Hi all.
so after i closed all my 7 printers I can print abs for 40+ hours without a problem with heat lamps.
the problem is that the Zero Lash Straps snap after a short period of time. any good solution to it?
is the SEEMECNC BALL-CUP DELTA ARM KIT with the new style injection molded carriages is better the tricklaser mod?
thanks
Nylocke
Re: Zero Lash Straps from tricklaser problem
Post by Nylocke »
I think Tricklaser is now selling springs instead of bands, You can probably ask Brian to send you some of the new tensioners for less than the arms.
ccavanaugh
Post by ccavanaugh »
216 / 217 size o-ring will work also. I use an ultra-flow durometer silicone material. The buna's and viton's would be too stiff.
