Layer fan not activating during bridging
Koops
Post by Koops »
Hello,
I'm currently calibrating settings for achieving decent results via abs, I've reached the problem of bridging with such a material.
I'm attempting to run the layer fan when the extruder bridges, and I have selected the settings in mattercontrol, however the fan will not activate during bridging.
the fan works via manualcontrols, it however will not prompt when needed by itself.
any advice appreciated!
Kyle
Re: Layer fan not activating during bridging
Using a fan on ABS is a pretty effective way to ruin a part unless you know EXACTLY what you're doing.
You might want to try increasing your bridging speed instead.
IMBoring25
Post by IMBoring25 »
Open the generated gcode and see what code it's passing to turn the fan on and off. Compare to the RepRapWiki documentation on gcodes for Repetier firmware.
Koops
Post by Koops »
geneb wrote:Using a fan on ABS is a pretty effective way to ruin a part unless you know EXACTLY what you're doing.
I know how cooling effects abs, I'm trying to see if I can merely cool the first bridged abs because at the minute it's a pile of goo!
Koops
Post by Koops »
IMBoring25 wrote:Open the generated gcode and see what code it's passing to turn the fan on and off. Compare to the RepRapWiki documentation on gcodes for Repetier firmware.
I'll take a look. Thanks!
nebbian
Post by nebbian »
I've found that judicious use of a fan with ABS can greatly enhance printing quality... with the emphasis on 'judicious'. My ABS Marvins looked like poo until I printed a good fan duct and got my settings right.
That said, to help bridging, try adjusting your bridge flow ratio. If the filament is falling down while bridging, lower the ratio, this tends to stretch it out more. Too low and you snap the filament though. Increasing bridging speed can also help.
Koops
Post by Koops »
nebbian wrote:I've found that judicious use of a fan with ABS can greatly enhance printing quality... with the emphasis on 'judicious'. My ABS Marvins looked like poo until I printed a good fan duct and got my settings right.
How do I adjust the flow during bridging only?, not familiar with a particular setting for this.
nebbian
Post by nebbian »
Koops wrote: How do I adjust the flow during bridging only?, not familiar with a particular setting for this.
Koops
Post by Koops »
Is this matter control?
Koops
Post by Koops »
checked the code, I have the same code as displayed there, doesn't give me any further info to solve as to why the fans are not being activated during a bridge while printing.
nebbian
Post by nebbian »
Nope, it's slic3r.
I find that slic3r gives almost enough control over the printing process. I haven't found another slicer that doesn't frustrate me greatly within 5 minutes.
Since you're using Sli3r, check the Advanced page on the Print Settings tab. The field you're looking for is called "Bridge flow ratio".
Hop over to the Filament Settings tab and make sure that you've got "Enable auto cooling" checked and you've got valid values for the Min & Max fan speed. Check to make sure "Bridges fan speed" is 100% (or whatever works for you).
Good luck!
Koops
Post by Koops »
geneb wrote:Since you're using Sli3r, check the Advanced page on the Print Settings tab. The field you're looking for is called "Bridge flow ratio".
Good luck!
I'm using matter control,however if slicer is the better option I'll go for that instead
ramai
Post by ramai »
Matter control has the option of using Slic3r. Go to options and select Slic3r as the Slice Engine.
Cura slicer, Duet Wifi, iMac
Koops
Post by Koops »
ramai wrote:Matter control has the option of using Slic3r. Go to options and select Slic3r as the Slice Engine.
I see, will this enable the options further/different options?
ramai
Post by ramai »
The slicing options in matter control change depending on which slicing engine you have selected.
Koops
Post by Koops »
ramai wrote:The slicing options in matter control change depending on which slicing engine you have selected.
thanks all for the help, I'm slowly getting closer to understanding the software/hardware :)
