Cyclone seperator for my CNC
				Khalid Khattak
Its time to print cyclone separator for my CNC router.
[youtube]http://www.youtube.com/watch?v=v_Gm0w5RTD4[/youtube]
- Captain Starfish
Re: Cyclone seperator for my CNC
Nice. I was going to but then found one on eBay for ten bucks, my time is worth more than that.
Wow - what a difference they make!
				Khalid Khattak
Mr. Captain, You are lucky to buy from ebay..unfortunately i don't have paypal to purchase from ebay  .. here is the completed half portion took around 8hours...
 .. here is the completed half portion took around 8hours...- barry99705
Yes they do! Though if you use a plastic bucket for the bottom, they will get soft after a few hours! This one is permanently collapsed.Captain Starfish wrote:Nice. I was going to but then found one on eBay for ten bucks, my time is worth more than that.
[img]https://lh3.googleusercontent.com/-snan ... 135248.jpg[/img]
				Khalid Khattak
- barry99705
It's pulling warm air from the router through it. That and with the door closed to my shop it gets quite warm in there. My shop vac is probably a little too powerful as well.Khalid Khattak wrote:barry why it becomes soft?... !!!!
My lowes bucket did the same thing with a 5.5HP shop vac.  Ended up using a chlorine bucket with a screw lid. It's half the size but thicker.
						- Windshadow
I used the metal tank of an old 1960s vintage smaller shop vac (about 6 or 7 gal in size) that I found at the dump years ago I kept it as it "Might come in handy one day"
I use a "Cyclone lid" on a 30 gallon garbage can.  Works great!
This thing: http://www.leevalley.com/US/wood/page.a ... at=1,42401
- barry99705
I collapsed a steel garbage can. Was cleaning up under the chop saw and a chunk of plywood stuck to the end of my vac hose. Can just folded into itself. I have an issue of shopnotes around here somewhere that has plans for a wooden cabinet for my cyclone. Uses paper leaf bags in the bottom so they can just be thrown into the compost heap/bonfire with no issues.geneb wrote:I use a "Cyclone lid" on a 30 gallon garbage can. Works great!
Ahh, here it is!
http://www.woodsmithplans.com/plan/smal ... collector/
						- Captain Starfish
My shopvac already has that arrangement built in, Gene, but the paper filter still managed to clog up all the time. Since adding a proper cyclone (the sloped walls etc add a lot more effectiveness to the inlet/outlet arrangement) it's been so much better again.
I use it with my ShopBot and it works great.  My vac source is a 1.5HP dust collector with a 4" hose.
I haven't actually gotten around to installing it and doing anything with it yet, but this is the one that I printed. http://www.thingiverse.com/thing:285743 I need to modify the top cap to fit my regular shop vac's hoses, though. I liked the internal fins of the design.
[img]http://i.imgur.com/Ae73jjQ.png[/img]
- barry99705
I wonder if the fins actually help or will they just perturb the airflow enough to kick dust into the exhaust flow?
https://youtu.be/hgmlSSicKZ0?t=210
I saw this a few days ago. I would assume his spiral works because it physically deflects the dust, but the small spiral in the design above doesn't seem like it would be that effective is this situation. I'd be willing to bet that the spirals width is likely inversely proportional to the length of the cone and the air speed. similar to how the riffling on a gun barrel is very shallow but effective.
- barry99705
What's real fun is to suck up a coin or washer.  They just spin around the top at a billion miles an hour until something hits them, or you shut off the vac!
						- barry99705
[img]https://lh3.googleusercontent.com/-FDcq ... 232228.jpg[/img]
Well that's bucket number 2.
   I think it's a combination of the heat, it's been in the low 90's, upper 80's since I turned on the vac, and the amount of time it's running.  This is after 4 hours continuous.  Checked the hoses, nothing is clogged.
  I think it's a combination of the heat, it's been in the low 90's, upper 80's since I turned on the vac, and the amount of time it's running.  This is after 4 hours continuous.  Checked the hoses, nothing is clogged.Never do anything you don't want to have to explain to the paramedics.
those buckets are shit. i took a nice thick 5 gallon that used to have paint in it... solidbarry99705 wrote:[img]https://lh3.googleusercontent.com/-FDcq ... 232228.jpg[/img]
