DIY curing oven...
Vat designs and coatings etc..., Electronics and mods, Z stages and mechanisms to release the prints from Vats etc...
DIY curing oven...
I've been doing some research in order to get all the data I need in order to get the DropLit v2 user manual written. One of the last things on my list was something to do the "final" cure on the part after it had been printed. A friend turned me on to this: http://forum.formlabs.com/t/budget-uv-cure-box-jar/3176.
Here's my version:
[img]http://www.geneb.org/duet/curing-oven-1.png[/img]
[img]http://www.geneb.org/duet/curing-oven-2.png[/img]
[img]http://www.geneb.org/duet/curing-oven-3.png[/img]
You fill it with water and leave the printed part in it for 30 minutes or so. The water prevents oxygen from slowing down the curing process that the UV is doing.
Re: DIY curing oven...
Great job Gene!
Thanks for sharing the pictures with us. There is something pretty about seeing the light given off by the LEDs.
Originally I was going to use duct tape that had bacon printed on it, but I chickened out at the last second and got plain blue instead. :)
barry99705
Post by barry99705 »
Won't the water block the UV?
Nope! (But you made me check!) :D
sgraber
Post by sgraber »
Make sure whatever container you choose doesn't block UV. Polycarbonate will block UV up to about 405-410nm.
sgraber, it's glass.
geneb wrote:Originally I was going to use duct tape that had bacon printed on it, but I chickened out at the last second and got plain blue instead. :)
How do they print bacon?
Inquiring minds want to know? :)
Ha! I wish!
Windshadow
Post by Windshadow »
I bet Proto Pasta would do a bacon scented filament if you asked them nicely
Might not taste very good though;-)
Return to “DropLit”
