I added and aluminum spreader to my bed, and so now it takes much longer to heat the bed. often times when i set the bed to 90c or more, it shuts off the heating before it even gets 75% there.
Where in the firmware can i extend this timer? I've been looking through the files in arduino but I haven found anything concrete and just want to make sure I'm adjusting the correct value. Thanks!!!
Looking to extend the shut off timer past 20 minutes
shentheory
Re: Looking to extend the shut off timer past 20 minutes
Bumping message, any firmware experts to answer this question?
- Tincho85
No expert here
, but you can change it though the EEPROM.
Fourth value:
Max Inactive Time
Mine is set to 1800000 ms (30 minutes)
Fourth value:
Max Inactive Time
Martín S.
