 I can print test cube easy. Everything fine.
But with bigger model I get a Layer Shifting , very accurate , after 50% of print.
I checked everything. belts and carriage. And cant find a problem.
 Maybe one stepper die ? How to check this ?
 It's doesn't matter. i print this model before many time with little different details.IMBoring25 wrote:How much bigger model? Is it lifting on the corners? What travel speed are you using? Are the motors getting uncomfortably hot to the touch? Which motors are they and what current do you have set?
