I purchased a Rostock Max kit at the Maker Faire a few months ago (thanks again to the SeeMeCNC staff for patiently answering my questions), and finally got time to assemble it over the 4th of July weekend. To my pleasant surprise it actually worked straight away...up to a point. With the exception of a E3D v6 hot end, I built the whole thing exactly per the excellent instructions scripted by Gene Buckle. My question pertains to printing the two fans shrouds in ABS as per those instructions. I sense this may be one of those questions that may annoy those who've heard it asked a bajillion times before, but please bear with me
Finished printer
I'm using 1.75 black ABS from Matter Hackers, and though the bottom edges of the 1st shroud peeled up a bit at the ends of the longest axis, the print completed. I've tried to print the 2nd shroud six times now and each time it gets to about he same height before coming loose from the glass bed. The bed is set to 80° C (except where noted below) and I verified that temperature to be within +/- 5° C using one of those no-contact thermometers. The hot end is set at 228° C.
- A little bit of glue per the instructions
- A moderate amount of glue
- Far too much glue
- Setting the bed to 100° C
Bottom view
Side view
What would you recommend at this point? I can keep casting about (as I have) but if there is anything obvious I should try then I would certainly appreciate your input. Thanks for looking!
-Kevin
