Hello,
I was wondering about layering.
Should i do
Heat Bed > Aluminum Spreader > Glass > PEI
or
Heat Bed > Aluminum Spreader > PEI
Tricker Laser Aluminum Spreader + PEI sheet
Qdeathstar
ccavanaugh
Re: Tricker Laser Aluminum Spreader + PEI sheet
1st option... you need the glass to keep the PEI flat. The relative flatness of the Trick Laser spreader is good, but not good enough for a consistent layer height.
Qdeathstar
Darn. Oh well
First option gives you flexibility and assures a flat PEI installation. Flexibility: you can easily remove the bed and flip it over to print on glass, etc.
