I've printed the above yellow shell again with a different PLA filament (low cost PLA which gave me good results so far). (from
http://www.thingiverse.com/thing:1559232). It's the outer shell. Strangely I've found some irregularities similar, but not identical to what I've seen on the yellow part already. I decided to print it out again (printout 2)  and to my surprise, the error pattern was identical. This is yery strange to me. Any hint what can cause this?
Interestingly to observe is that also the banding on the shell has a identical pattern. The print speed was 40mm/s.
Thanks for any help to clear this mystery.
*John*
