Sd card support?
Sd card support?
If you want to use SD card support with Repetier you have to yous the polygonhell firmware, Is that right?
Re: Sd card support?
I see John released a new marlin 2 weeks ago that includes SD support and the description says this is a candidate for Marlin 1.0.0, does he mean Auduino 1.0.0?
Or still I use Arduino .0023?
Bill
Bill
I know the Polygonhell firmware does support SD cards, but if the new marlin release says SD support, it will work with the included LCD panel.
Arduino is something different - that's the SDK used to program the arduino side of the control board (RAMBo) - it's only used to upload the firmware. If you used Arduino 0023 before, stick with that, I'm running arduino 1.0.1 and have no issues uploading firmware.
I was using polygonhell but when I move the nozzle to any tower the head would sweep downward to the table, what line should I look for to fix that?
I see a line in config h called string version 1.0.0, sounds like that's what it means....
