I'm a web developer by trade with a bit of background in robotics, but I do a lot with music as well--specifically, I'm a trumpet player. Once the two extra layer blower fans I've ordered arrive, I'm looking forward to switching from my current ABS filament to PLA and trying to print a few trumpet mouthpieces as my first project! I've seen several different mouthpiece designs on Thingiverse, and had a few questions I wouldn't mind getting answered by someone with more experience (or answering myself through experimentation, if required!).
- What material would you recommend for a trumpet mouthpiece? I've heard ABS isn't the healthiest stuff, and I've certainly experienced some respiratory and eye irritation when I'm in the room while it's printing. While obviously my ABS printing temperature of 228C is a bit warmer than what you generate while playing the trumpet, trumpet mouthpieces do get very warm while playing, and it is literally pressed up against your mouth and very near your nose. There's a lot of friction involved in playing the trumpet, and I could see ABS causing some irritation with prolonged use. All that said, I've also heard PLA isn't the best material to sand down, and the inside of the mouthpiece will definitely have to be sanded until perfectly smooth in order to be comfortable and remove as much air resistance as possible. Whatever material I end up using will need to be able to stand up to a fair amount of heat, pressure, vibration, and moisture, but I'm guessing most of the normal materials (PLA, ABS, potentially PETG) will be easily able to stand up to normal circumstances.
- On the Thingiverse page, I noticed there's a couple "parametric" mouthpiece designs. If I'm interpreting that correctly, that means the designs are adjustable via input parameters--are these parameters adjustable in slicer programs (MatterControl, Cura, etc), or will I need third-party CAD software to do so?
- What CAD software would people recommend for a guy on a budget? I have some basic CAD experience, but that was back in 2005 or so and most of it was with polygon-based modelers rather than solid modelers, so my experience is very nearly irrelevant to modern CAD software. The computer I'm running the printer from has moderately beefy specs, so that shouldn't be too much of a concern, but I'm honestly not sure where to start looking for reasonably-decent CAD programs for personal use.
