Hi there,
I am wanting to machine an aluminium build plate for my rostock max V2.
I was wondering what dimensions people used when they do these? Diameters and thicknesses.
http://download.seemecnc.com/rostockmax ... dition.pdf - and others has diameter as 300mm
https://www.seemecnc.com/collections/pa ... late-310mm - has diameter as 310mm.
I was also wanting to know thicknesses of aluminium I should use for a heat spreader. Should I make it thicker if I want to print directly onto the aluminium surface?
Thanks
Matt
Dimensions for new build plate
Re: Dimensions for new build plate
The Onyx page goes into more detail about the dimensions of the bed itself, the diameter of the mounting holes, etc.
I think the Trick Laser heat spreader plates are 1/8". That does a find job for me.
Hi,
I would like to know if its better to put the glass on the aluminium plate or directly print on it ?
thanks !
thanks !
I do Glass on top of the aluminum on top of the Onyx. That way the heat gets spread out evenly before it hits the glass. That's what I tell myself, anyway.
