I just finished building my Rostock v3 last night and I was able to print a number of things (boaty, fossil fish, and vase), but for some reason I cannot print a stretchlet. I add the stretchlet.stl to my printer queue, hit print, my bed + nozzle heat up to the correct temperature the hotend lowers to attempt the print and resets to zero. The one thing I noticed when I got to layer view is that this particular print did not have any layers associated. Is that my problem?
File I'm trying to print:
http://www.thingiverse.com/thing:13505/#files
Unable to print Stretchlet in Matter Control
Re: Unable to print Stretchlet in Matter Control
I believe it's the minimum feature size. Take stretchlet1.stl, set it to no top or bottom, and also vase mode. That should do something.
Thanks. I'll try that tonight.Xenocrates wrote:I believe it's the minimum feature size. Take stretchlet1.stl, set it to no top or bottom, and also vase mode. That should do something.
