New machine configuration wtk 4-axis board
bvandiepenbos
Post by bvandiepenbos »
Hi all,
I am just getting my H1 running but it won't move, wiring wrong?
One of those 4-axis boards.
Using Mach config from this forum, posted by mhackney
motor wiring as shown on drawing from SeeMeCNC for 3-axis;
---green
---black
---blue
---red
board switches;
1-off
2-on
3-on
4-on
5-off
6-off
Also, what temperature should I start with?
And what pins should I jumper when I remove opto isolaters?
~*Brian VanDiepenbos
Goshen, IN
Re: New machine configuration wtk 4-axis board
Brian, start with basics,
when you power on and enable mach (the big RED estop button at the lower left on the screen) do you hear and feel the steppers energize?
If not, then we need to get that sorted. I am now using the 4 axis board so I can send some photos later.
As for temp, that is controlled manually by the velleman thermostat. Lets leave that unplugged (disconnected) until we get your axis moving!
cheers,
johnoly99
Post by johnoly99 »
Just left Brians house (hes literally 2 miles from our shop!) And he now is the oriud papa of a running, printing "little squirt"
Great! What was the problem? It might help others to know.
cheers,
martinezfrank95
Post by martinezfrank95 »
great i have the same problem what did you do can you come to my house and fix it too???????????????????
