http://www.thingiverse.com/thing:271736
I would be grateful of some feedback from someone with more experience of the Max v2 as to whether they think the print quality is good or bad. I should say I installed a cartridge heater instead of the 2 resistors in the stock hotend.
for some reason 1 side of the cube hasn't printed so good as the others??
Top to bottom its 20.15mm
and across its sides its 19.81mm
My guess is I need to apply a slight scaling to allow for the shrinkage of the abs as per the manual indicates. Comparing the picture of my cube against the pictures on Thingiverse mine doesn't look bad at all
