I agree with everything Xenocrates said. However, you did not list your material and print speeds. It looks like you have layer shift artifacts that could be the result of printing too fast or mechanical slop/backlash. Slow down and see how it affects your prints. Better yet, read the posts linked in my signature to learn even more.
And as the forum's UDS ("Unofficial Duet Spokesperson") let me make a few comments about Duet:
The primary distinction between the v0.8.5 and Duet Wifi for our purposes is Wifi. It adds $40 to the cost. You can use a 0.8.5 with a $20 Wifi bridge (its on my blog) but it is not as clean or as fast as the native Duet Wifi. There is also a .6 board available from
China and the
UK. I have 1 of each of these and they work perfectly fine. I recommend the UK one though as the external voltage regulator on the Chinese one can create confusion on how to wire. Both of these are under $77US (plus shipping) and you can use the same Wifi bridge to get Wifi.
If money is a concern, get the .6 version and Wifi bridge if you want wifi connectivity. You can also connect via ethernet or USB but you DO WANT to use ethernet or wifi, it is much much faster and the built in Duet Web Control is extremely nice.
If money is not a major concern and/or you think you might want to upgrade to 3 or more extruders or other fancy stuff in the future, go with the Duet Wifi. It is shear elegance in a 3D printer controller. The DWC does temperature graphing and a lot of other things. Scroll down to Electronics on my blog post:
http://sublimelayers.blogspot.com/search?q=duet
A couple of other significant comments: I've used all of the major controllers and firmware available today. By far, the Duet/RepRapFirmware (aka dc42) has the best user experience for everything from configuration to firmware upgrades to actually printing. The configuration is all done in simple configuration files (no EEPROM) and can actually be edited in the Web interface - the way life was
meant to be. This feature alone is awesome but it gets better, you can also upgrade the firmware via the web interface! No more Arduino IDEs, compiling and uploading hassles, no more pulling out the SD card and hoping you don't forget to unmount it before printing nonsense. The firmware is provided as a binary ready to upload and go. It is pure elegance. These capabilities provide for the most user friendly and seamless management of your printer. But it gets better! Printing. It is soooo simple to upload a gcode file (and fast) via the web interface. You can control all features of your printer, print and monitor (including the temperature plot) etc. OctoPrint and AstroPrint pale in comparison.
There are many more features like macros that add to the experience. My second piece of advice is, if money is an issue, don't worry about the PanelDue. With the web interface and wifi you don't need it. I rarely use mine. It has some great features like touch screen and color but it isn't at all needed with the built in DWC.
Oh, and invest in either the IR probe or FSRs or the accelerometer probe I'll have available early next year and experience the joy of the dc42 auto calibration. It is still the best autocalibration available. And I have it on good authority that delta grid leveling is scheduled for the next (1.17) release hopefully before the end of the year. Once that is available, it really is game over for all the other firmware and controllers in my opinion unless you are buying something else for economic reasons. But if you do the math and figure out how many hours of frustration and inferior results you'll get with other solutions, the Duet/dc42 combo is a bargain.
