anti warping disc
anti warping disc
how do I manipulate kisslicer so that I can add anti-warping disc's to my prints.
no matter what i do, i can't seem to get it where I want to place it, what's the technique here?
in other words, how do you get the disc underneath the printed objects?
Re: anti warping disc
Never used KISS, so I can't comment on the 'right way'. But there's always more than one way to solve a problem. You can try this in the meantime:cambo3d wrote:how do I manipulate kisslicer so that I can add anti-warping disc's to my prints.
http://www.thingiverse.com/thing:16728 (It's slow to run, but is effective)
no i'm talking about adding anti-warping disc below the print..
- foshon
cambo3d wrote:no i'm talking about adding anti-warping disc below the print..
I have seen them called mickey mouse ears as well.
Purple = sarcasm
yes that's it, can you add these in kisslicer below the print or does it have to be done prior?foshon wrote:cambo3d wrote:no i'm talking about adding anti-warping disc below the print..
No you have to edit the original model to add those.cambo3d wrote:yes that's it, can you add these in kisslicer below the print or does it have to be done prior?foshon wrote:cambo3d wrote:no i'm talking about adding anti-warping disc below the print..
I see, thanks!
Actually, I think i found the setting.No you have to edit the original model to add those.
Bet roughness just increases the height of the first layer.jesse wrote:Actually, I think i found the setting.No you have to edit the original model to add those.
- foshon
Polygonhell wrote: No you have to edit the original model to add those.
Would it be possible to have stl's of varying sized circles and use the multiple model method to position them under the corners of the main print?
Purple = sarcasm
Most likely not, I've not tried it, but most slicers are extremely sensitive to bad geometry and don't like overlapping pieces.foshon wrote:Polygonhell wrote: No you have to edit the original model to add those.
As Dear Mr. Owl said, "Let's find out."Polygonhell wrote:I've not tried it
I have heard these things called a number of different names, but let's go with a fanciful one: frog toes. They are designed to latch onto the print bed, and give the minimum amount of easy knife cleanup work.
I quickly mocked up a simple 300 micron x 3mm radius frog toe STL, and a test part that is a simple half-cylinder shell.
[img]http://i.imgur.com/bX87Rl7h.png[/img]
[img]http://i.imgur.com/nFhBsTUh.png[/img]
I then took them over to Slic3r 0.9.9, the current version at this time. It had no conniption when parts overlapped.
[img]http://i.imgur.com/IeiFo12.png[/img]
To confirm what I'd see on the print bed, I previewed the gcode in Pronterface. I know Repetier-Host's preview is more fancy, but I just don't like the rest of that app for some reason.
You can see some of Slic3r's shortcomings, but complaining about overlap wasn't one of them. The rasterizing code decided that there was no rectangle at the west end of the half-cylinder part, but the next layer up shows it just fine. I would need to save ASCII STL to see why that is, but I expect the west end's vertices are not at exactly Z=0.00000.
The frog toes are all included in the gcode, but might pose a little problem on non-heated beds. The paths are clearly overlapping instead of being incorporated as a union of shapes. The nozzle might push one path off the bed entirely if there was enough cooling between the two overlapping parts.
[img]http://i.imgur.com/BjzNrbA.png[/img]
I'm trying to get a handle on this warping with abs, so far i'm losing this battle.
I may end up swapping to pla when all my abs is used up. already prepping my rostock for it.
- foshon
cambo3d wrote:I'm trying to get a handle on this warping with abs, so far i'm losing this battle.
Have you tried ABS juice. It's a bit messy, but I must admit that since switching to ABS juice and lowering my bed temp I been able to print some fairly sexy stuff with no/very little warping.
I swiped the end of a bottle of the old ladies nail polish remover. Oddly enough for a bit I thought the whole thing was hoopla. Turns out there is a fair amount of not acetone stuff in commercial nail polish remover. After I poured out the purple perfume liquid and added a bit more acetone I ended up with a thin pudding like gel that wipes on in thin layers with a paper towel.
There is no way to remove a part with the bed at temp without bending the snot out of it. Once everything cools though, a quick run around the part with a sharp knife and it peels right off.
Purple = sarcasm
i'll give abs juice a try, i've just been using hairspray. need to go get some acetone.
- gsnover
- Prints-a-lot
I have been using abs juice and I haven't had anything curl. I also use a brim. Every geometry is different, but it's been working for all my vase forms so far.
It's difficult to keep. The rubber seal in mason jar I am using is deteriorating fast. Maybe a small metal paint can would be better. I prefer to apply using a cheap foam brush. If you dip the brush in too far it will melt the glue holding the foam to the brush handle, but if you just dip the tip I find it puts on a nice even coat. Just let it dry hard afterward, you can reuse it no problem.
Rostock Max - Shakira "her hips don't lie"
Rambo 1.1 | Onyx | LCD | Marlin-for-Rostockmax-RamboLCD
KISSlicer
KISSlicer
finally gave abs juice a try and it seems to be working,
i'm 4hrs into a 16hr print and this thing seems to be well attached to the build surface. no signs of warping so far.
- gsnover
- Prints-a-lot
Cambo3d how are your ball joint arms working out? I saw trick laser has some nice ones for sale, but I haven't seen a lot feedback on that type of replacement. Do you think they will wear well and stay precise?
KISSlicer
KISSlicer
see here http://forum.seemecnc.com/viewtopic.php ... 280#p10225gsnover wrote:Cambo3d how are your ball joint arms working out? I saw trick laser has some nice ones for sale, but I haven't seen a lot feedback on that type of replacement. Do you think they will wear well and stay precise?
