While we have a lot of FDM experience (and several other printers) this is our first delta style.
We started in 2013 and have worked our way through a number of prusa style and even a DLP we built ourselves.
Other than the fact that this is a delta we are not entirely new to this
Other than a too-short strip of bowden (we extended it 2 feet and they apparently had a bit of an issue figuring out how much to send us) everything was in the kit and it was not a big deal to assemble.
Unfortunately printing has been another issue. The extruder would not keep up with the hotend (all of this is using standard PLA by the way) and would begin skipping with extrusions of any length at or above about 100mm. Went back and forth with support a fair amount and never could isolate the exact problem. They ended up sending us an assembled effector (awesome!) however... it behaves the same way. I have toggled between the provided EZRStruder and a GregsWade to no avail. The EZR will soon after starting a print begin skipping and fail after the first layer (that usually comes out OK). The GregsWade likewise will just start wadding the filament up at the tube. Clearly too much back pressure. Mind you this is an entire effector that they assembled and sent us, behaving exactly the same as the one we built.
If we test the hotend loose with it heated up and using a short piece of bowden tube to manually feed in some filament it is very difficult to get any to extrude. Our other units (sadly all using E3D hotends) are very easy to manually push filament though by hand, but this one (and the original we built) are not. This is much harder to manually push filament through it.
At this point I am sure the back pressure is what causes the problems, but the best I could get was with a 2.0 mm (yes, you read that right) nozzle and even then eventually the extruder will fail to push it through.
Any ideas on what to try? I have plenty of other bowden tube, but changing that did not seem to affect this. I figured the GW would handle any minor extra extrusion pressure easy enough, but ... nope.
The back pressure is enough that I am convinced this is what killed the extruder stepper early on (we had a set of extras, but swapping that for a new one did not solve it -- the original is well and truly dead though).
