Rostock Max v3 EZRStruder Filament Sensor for Octoprint
rocky00717
Post by rocky00717 »
Hey Guys,
I modified the EZR struder to include an optical filament sensor.
http://www.thingiverse.com/thing:1913357
It prints but i haven't hooked it up yet. Welcome any feedback. :D
joe
Re: Rostock Max v3 EZRStruder Filament Sensor for Octoprint
Post by joe »
So something like this? Less your extruder
https://www.kickstarter.com/projects/20 ... nd-cleaner?
wshiwsbrding
Post by wshiwsbrding »
rocky00717 wrote:Hey Guys,
I just ordered my RM v3 tonight! I would love to see pictures of your modified EZR struder to start planing my theoretical optical filament sensor.
Also, Joe that one looks like it will be a really nice option.
smgvbest
Post by smgvbest »
I printed this up and it does not work as is with the EZRstruder, The EZR I guess went thru a design change and the where the filament exits the EZR has changed. the use the same 4mm coupling as the HE280 uses which requires a design change.
I check the Github drawings and they don't reflect this change either. and the solidworks file is hard to disassemble to get just a the base.
Did you modify the solidworks file or the STL to make these change you made,
Current printers
Rostock Max V3
Flashforge Creator Pro
Prusa i3 mk3 w/mmu (TBP)
kfonda
Post by kfonda »
Hi
I was wondering if anyone ever made the changes to the 'EZRstruder optical filament sensor' to allow it to work with the current EZRstruder.
Kevin - fairly new to this whole 3d printer stuff :D
Return to “RostockMAX v3”
