Trouble with V3 Z offset using old and new firmware
timskloss
Post by timskloss »
I am having trouble calibrating the bed on my V3. I have tried both the 'old' V3 probing gcode file from SeeMe and the new development firmware. In both cases I am getting a Z0 that is about 0.15 mm above the bed. This measurement is consistent at +/- 100 mm in x/y so the bed is pretty flat. I always clean the nozzle and run the calibration with cold bed and extruder.
I discovered the offset after a lot of frustrating work trying to get ABS to stick to the bed--the nozzle was just to high.
Currently I am using a Z offset of -0.07 mm and it seems to give a decent first layer, but I want to fix this problem in the printer so Z0 is really at 0.00 mm. Here are the EEPROM settings after running the new development firmware:
<-EPR:2 79 900000 Max. inactive time [ms,0=off]
<-EPR:2 83 600000 Stop stepper after inactivity [ms,0=off]
<-EPR:3 11 80.0000 Steps per mm
<-EPR:3 23 250.000 Max. feedrate [mm/s]
<-EPR:3 35 80.000 Homing feedrate [mm/s]
<-EPR:3 39 32.000 Max. jerk [mm/s]
<-EPR:3 133 0.000 X home pos [mm]
<-EPR:3 137 0.000 Y home pos [mm]
<-EPR:3 141 0.000 Z home pos [mm]
<-EPR:3 145 250.000 X max length [mm]
<-EPR:3 149 250.000 Y max length [mm]
<-EPR:3 153 402.388 Z max length [mm]
<-EPR:3 59 1850.000 Acceleration [mm/s^2]
<-EPR:3 71 3000.000 Travel acceleration [mm/s^2]
<-EPR:3 881 291.060 Diagonal rod length [mm]
<-EPR:3 885 143.901 Horizontal rod radius at 0,0 [mm]
<-EPR:3 925 200.000 Max printable radius [mm]
<-EPR:1 891 80 Segments/s for travel
<-EPR:1 889 200 Segments/s for printing
<-EPR:1 893 65 Tower X endstop offset [steps]
<-EPR:1 895 0 Tower Y endstop offset [steps]
<-EPR:1 897 87 Tower Z endstop offset [steps]
<-EPR:3 901 210.000 Alpha A(210):
<-EPR:3 905 330.000 Alpha B(330):
<-EPR:3 909 90.000 Alpha C(90):
<-EPR:3 913 0.000 Delta Radius A(0):
<-EPR:3 917 0.000 Delta Radius B(0):
<-EPR:3 921 0.000 Delta Radius C(0):
<-EPR:3 933 0.000 Corr. diagonal A [mm]
<-EPR:3 937 0.000 Corr. diagonal B [mm]
<-EPR:3 941 0.000 Corr. diagonal C [mm]
<-EPR:3 808 -0.200 Z-probe height [mm]
<-EPR:3 929 20.000 Max. z-probe - bed dist. [mm]
<-EPR:3 812 90.000 Z-probe speed [mm/s]
<-EPR:3 840 50.000 Z-probe x-y-speed [mm/s]
<-EPR:3 800 0.000 Z-probe offset x [mm]
<-EPR:3 804 0.000 Z-probe offset y [mm]
<-EPR:3 816 -123.565 Z-probe X1
<-EPR:3 820 -71.340 Z-probe Y1
<-EPR:3 824 123.565 Z-probe X2
<-EPR:3 828 -71.340 Z-probe Y2
<-EPR:3 832 0.000 Z-probe X3
<-EPR:3 836 142.680 Z-probe Y3
<-EPR:0 880 1 Autolevel active (1/0)
What is the 'correct' way to adjust so I don't have to worry about it when slicing?
Thanks in advance!
Re: Trouble with V3 Z offset using old and new firmware
Tim, there is a configuration parameter in EEPROM called something like Z-Probe Height - you can see it in your post above. By default that is set to -0.20mm but I assert that it really should be tuned for each printer. I posted instructions in my V3 build thread 2 weeks ago or so.
This offset is ADDED to the measured Z height to compensate for systematic probe trigger offsets like switch actuation, bed movement, etc. You should be able to tweak as per my thread and be dead on.
Also, a word for folks reading this NEVER compensate for Z=0 in your slicer. That is a recipe for frustration and failure. Adjust your machine and calibrate Z height. Read the post in my signature for more information on how to do this. It is the only way to get consistent first layer thickness and adhesion.
timskloss
Post by timskloss »
Mike, you are a BIG help. I made good progress this morning. I should have read your V3 build thread all the way through a week ago. :oops:
-installed EEPROM reader into Octoprint
-changed probing locations to match your new ones
-optimized the end stop screw positions
-ran back to back calibrations using the new development Auto Calibration firmware
X end stop		-1		1		0		1
Y end stop		-1		0		0		0
Z end stop		 1		3		2		2
Horz Radius		143.963	143.956	143.956	143.949
Z Max Len			402.250	402.231	402.244	402.238
The repeatability looks good I think.
timskloss
Post by timskloss »
After the calibration above I checked my nozzle-bed gap at Z0 and still found about 0.16mm gap. I changed the Z probe height in the EEPROM from the original -0.20 mm to -0.04 mm and after a new calibration run the height is within 0.01 mm. :D
I'm a happy camper now and look forward to taking out the Z offset from the printer settings in my slicers.
Thanks again for the help!
Yup, that looks like consistent calibration results and your change to Z probe height should work great now.
Next...
