Can anyone help me print a better Benchy?
WLJayne
Post by WLJayne »
Hey guys,
I've been playing around with the settings on my V3 for a few days and I have got better, but I'm still not happy with the prints. Can anyone suggest ways to correct the issues I'm having? This last Benchy was printed in PLA with:
Speed:
Temp: 210
Infill: 40mm
Inside Perim: 30mm
Outside Perim: 20mm
Travel: 300mm
Retraction:
Length on move: 5mm
SpeedL 100mm
Z lift: 0.1mm
Minimum travel: 2mm
No wipe
I'd really like to get rid of the blobbing, but I'm generally quite happy with the prints otherwise. Can anyone suggest something to try?
Re: Can anyone help me print a better Benchy?
They used to have a visual troubleshooting guide. http://www.3dbenchy.com/category/troubleshooting/ That doesn't seem to be working anymore...
The other goto guides that you should reference are here:
http://support.3dverkstan.se/article/23 ... ting-guide
https://www.simplify3d.com/support/prin ... eshooting/
http://reprap.org/wiki/Print_Troublesho ... rial_Guide
WLJayne
Post by WLJayne »
Thanks, those helped a lot. Adding a negative value to restart extrusion has done a lot to fix it. Now I just need to find the right balance.
One day I will reach the Benchy limit. But it is not this day.
626Pilot
Post by 626Pilot »
Do my dimensional accuracy calibration (link in sig) to make sure your geometry is set up just right. Whenever you get a new spool of filament, measure it using an outside micrometer in ten different places a foot or two apart, skipping the first few feet because they're usually somewhat kinked, and put the average in your slicer. Then, do step 1 of the dimensional accuracy calibration (single-walled box) to get it just right.
Change your retraction speed to 15mm/sec. You can also try a wipe setting. I find 10-15mm is very good on my E3D Cyclops. You might also want to try a retraction length of 3mm, but I'm not sure if your hot end requires it to be that short.
Make sure your extrusion temperature is not too high. It should take a little bit of effort to push the filament through. If it goes through with very little resistance, it may cause blobbing, which there is a lot of on one of those 3DBenchy prints.
