Trouble printing some of MHackney's reels
TMIB
Post by TMIB »
I've recently made some upgrades to my Rostock, as well as switched over to using KISS slicer and Octoprint on a Raspberry Pi. I've had some good prints, but just recently tried printing a new fly reel and am having some troubles.
First off here's some pictures of what the problems are:
The pillars do not have solid exteriors:
[img]http://i.imgur.com/WQfH8Nv.jpg[/img]
The top surface has gaps:
[img]http://i.imgur.com/RrQhz0U.jpg[/img]
The back sides are not too bad, but there are a few small gaps:
[img]http://i.imgur.com/S0t5ieb.jpg[/img]
[img]http://i.imgur.com/izrdo28.jpg[/img]
Below are my KISS Slicer settings. I can post the GCode too, if that's ok with you Mike.
_material
[Hatchbox Blue PLA]
g_code_matl=3B204D617962652073657420736F6D65206D6174657269616C2D737065636966696320472D636F64653F
fan_Z_mm=6
fan_loops_percent=65
fan_inside_percent=65
fan_cool_percent=80
temperature_C=200
keep_warm_C=165
first_layer_C=200
bed_C=72
sec_per_C_per_C=0.00681818
flow_min_mm3_per_s=0.5
flow_max_mm3_per_s=10
destring_suck=2
destring_prime=1.5
destring_min_mm=1.5
destring_trigger_mm=5
destring_speed_mm_per_s=25
destring_suck_speed_mm_per_s=55
Z_lift_mm=0.5
min_layer_time_s=10
wipe_mm=5
cost_per_cm3=0
flowrate_tweak=1
fiber_dia_mm=1.72
color=4294967040
_style
[.2mm Layers]
quality_percentage=60
layer_thickness_mm=0.2
extrusion_width_mm=0.55
num_loops=4
skin_thickness_mm=0.5
infill_extrusion_width=0.55
infill_density_denominator=2
stacked_layers=1
use_destring=1
use_wipe=1
use_corners=1
loops_insideout=0
infill_st_oct_rnd=2
inset_surface_xy_mm=0
seam_jitter_degrees=360
seam_depth_scaler=0
seam_gap_scaler=1
seam_angle_degrees=45
_printer
[Rostock MAX]
bed_STL_filename=C:\Users\Tracy\Downloads\KISSlicer_Win32_1.5_Release\RostockBuildPlatform.stl
extension=gcode
cost_per_hour=0
g_code_prefix=4732380A4D31303420533C54454D503E0A4D31393020533C42454454454D503E0A4D31303920533C54454D503E
g_code_warm=3B2053656C6563742065787472756465722C207761726D2C2070757267650A3B2035442D7374796C650A543C4558542B303E0A4D31303420533C54454D503E0A
g_code_same_warm=NULL
g_code_same_cool=NULL
g_code_cool=436F6F6C2047436F64650A3B2047756172616E746565642073616D652065787472756465722C20636F6F6C696E6720646F776E0A3B2035442D7374796C650A4D31303420533C54454D503E0A
g_code_N_layers=3B204D617962652072652D686F6D652058202620593F
g_code_postfix=4731205837302059302046353030300A4732380A4D313430205330203B206B696C6C206265642074656D7065726174757265
every_N_layers=0
post_process=NULL
num_extruders=1
firmware_type=2
add_comments=1
fan_on=M106
fan_off=M107
fan_pwm=1
add_m101_g10=0
z_speed_mm_per_s=15
z_settle_mm=0
bed_size_x_mm=280
bed_size_y_mm=280
bed_size_z_mm=300
ext_radius=0
bed_offset_x_mm=0
bed_offset_y_mm=0
bed_offset_z_mm=0
bed_roughness_mm=0
round_bed=1
travel_speed_mm_per_s=500
rim_speed_mm_per_s=250
first_layer_speed_mm_per_s=10
dmax_per_layer_mm_per_s=50
xy_accel_mm_per_s_per_s=1500
xy_steps_per_mm=150
lo_speed_perim_mm_per_s=10
lo_speed_loops_mm_per_s=20
lo_speed_solid_mm_per_s=10
lo_speed_sparse_mm_per_s=10
hi_speed_perim_mm_per_s=30
hi_speed_loops_mm_per_s=65
hi_speed_solid_mm_per_s=30
hi_speed_sparse_mm_per_s=30
ext_gain_1=1
ext_material_1=7
ext_axis_1=0
Any suggestions? I've had good success printing these previously, but that was using MatterControl on a tablet, with MatterSlicer. My printer now runs the EZR struder and the new hot end with the accelerometer, so there have been significant changes since then.
Re: Trouble printing some of MHackney's reels
Firstly, yes its ok to pst the gcode, etc
The pillars look like extrusion issues. Do you hear clicking when these print? Also, what is your print speed? I didn't see it in the posted configuration. But it really looks like an extrusion issue.
TMIB
Post by TMIB »
No clicking noises. I used some other filament (white PLA) previously, and adjusted extruder step settings so that 100mm advances exactly 100mm. I suppose it could be different with this filament.
Here's my print speed settings:
[img]http://i.imgur.com/saaNEVB.jpg[/img]
I have the precision <-> speed bar set at 60% (quality_percentage=60)
You have a 2mm suck and only a 1.5mm prime, that will lead to voids at the start of segments.
You really want them set to the same value.
TMIB
Post by TMIB »
Polygonhell wrote:You have a 2mm suck and only a 1.5mm prime, that will lead to voids at the start of segments.
Good catch! I must have missed that when I last adjusted the setting. I'm going to try a test print now (50mm box) and see how it does.
I've had really good results printing Mike's reels before. I've got one on my 3wt fly rod and it's caught a lot of fish for me. It's so light the rod will actually float if I drop it in the water.
TMIB
Post by TMIB »
Well that's quite a bit better:
[img]http://i.imgur.com/PzfYCvc.jpg[/img]
Just changed the prime up to 2 mm. Sometimes it's the little stuff that makes a huge difference.
joe
Post by joe »
TMIB wrote: I've had really good results printing Mike's reels before. I've got one on my 3wt fly rod and it's caught a lot of fish for me. It's so light the rod will actually float if I drop it in the water.
Who is this Mike you speak of? He designs and makes 3D fly fishing reels?
Post by Mac The Knife »
He hangs out on this board occasionally. He is a big help to a lot of people, and if you send him an email, he may send you a link to download his files to print his reels for your own use.
"Some say he runs a notorious Penguin fighting ring, and it's rumored he sleeps with a Rostock MAX v1. All we know is, he's called mhackney!"
^ That's me and shhhh about the Penguins.
Check out www.eclecticangler.com and click the 3D printed fly reel link on the left side.
Good catch by Polygonhell. What I see now looks like slight layer registration issues - which is a mechanical issue with your printer (usually, slowing down can sometimes minimize/eliminate these as can printing outside->in perimeters as per my instructions). Check for loose belts, wiggly carriages, etc and adjust accordingly. Which arms do you have? The joints might be loose.
joe
Post by joe »
mhackney wrote:^ That's me and shhhh about the Penguins.
Check out http://www.eclecticangler.com and click the 3D printed fly reel link on the left side.
Yeah, I know. Just haven't heard you toot about your reels for awhile. :D
Ha, now I have!
TMIB
Post by TMIB »
I've got it set to print outside->in. Belts seem good, slowing down further is always an option. I'm running the ball/cup joints from the stock late model V2, attached to trick laser trucks.
That all sounds good. But it really seems like registration is a little off. What do you have for part cooling?
TMIB
Post by TMIB »
mhackney wrote:That all sounds good. But it really seems like registration is a little off. What do you have for part cooling?
I have the HE280 hot end with the 3 fans that come on it.
The unevenness could also be slight overextrusion, or printing slightly too hot/insufficient cooling for the filamanent, bith can look like mechanical issues.
Slow down and try setting the extrusion multiplier to 0.9, if it looks better at that then I'd print a few test pieces to recalibrate (Hollow cube/Soild cube).
BTW, if you've really got your x/y rapid travel speed set to 500mm/sec, you're begging to skip steps. Dial it back to 240-250.
TMIB
Post by TMIB »
I used the hollow cube calibration as well as the 50/100 mm cubes to adjust things. My extrusion modifier is now set to .96. My suck/prime is set to 2, and I brought the x/y travel speed down to 250.
Things are a little better, but there are still a few voids, and some banding:
[img]http://i.imgur.com/3PpAx0j.jpg[/img]
