Page 6 of 19
Posted: Fri May 10, 2013 9:47 pm
by elqisqeyano
Broose wrote:elqisqeyano wrote:Broose wrote:FIRST PRINT.jpg
First print. Looking good!!!
How difficult was it to JB weld the Balls to the cap screws?
Not hard at all. If the ball is sitting on the rod end with the magnet inside, the magnetism holds the cap screw to the ball. I kind of twisted the cap screws upside down into the JB weld to pick up just enough JB Weld on the top.
I had to carefully use small needle nose pliers on the side of the top part of the cap screw below the ball when installing the cap screw/ball combination, because it still takes a fair amount of force to screw it in, even though I ran a longer 3mm screw through first a few times to get the thread going. On the other hand, if I had a piece of latex rubber between my fingers and the ball, that might have allowed me to apply more force so that I wouldn't have needed the needle nose pliers.
Thank you.
Posted: Sat May 11, 2013 12:18 am
by elqisqeyano
This invention not only improves print quality dramatically, but it also elongates the life of the Rambo board due to it's smooth, minimal friction, movement. Motors don't get so hot cause they are working against so much less friction. Well worth the upgrade and cheap to acquire too.
Posted: Sat May 11, 2013 12:26 am
by ApacheXMD
elqisqeyano wrote:This invention not only improves print quality dramatically, but it also elongates the life of the Rambo board due to it's smooth, minimal friction, movement. Motors don't get so hot cause they are working against so much less friction. Well worth the upgrade and cheap to acquire too.
Really? Did your U-joints really have that much friction? Did you actually measure your motor temperature before and after? I find it hard to believe that the reduction in friction is quantifiable via motor temps.
Posted: Sat May 11, 2013 3:16 am
by bplemmons
Anyone have some before and after, print quality pics to share?
You can post them on what are you making...
Love to see them!!
Bill
Posted: Sat May 11, 2013 11:51 am
by cambo3d
need someone to 3d print this project for me since my machine is currently down. who can help?
I need this quick so I can get this machine back up and running. If you can do it please pm me.
trade ya led light assembly or some custom work for the rostock..or cash money.
Posted: Sat May 11, 2013 12:01 pm
by elqisqeyano
cambo3d wrote:need someone to 3d print this project for me since my machine is currently down. who can help?
What do you need? I can try my best to help.
Posted: Sat May 11, 2013 1:28 pm
by elqisqeyano
What you think? You have more experience than me on this 3D printing. I trust your judgement.
Posted: Sat May 11, 2013 1:32 pm
by elqisqeyano
I would be interested in an aluminum version of the effector that I can attach the balls to instead of using ABS. Due to the fact that I will most likely be printing at high temps. Could you provide me with an aluminum effector for this magnetic system? I would pay you for it.
Posted: Sat May 11, 2013 1:54 pm
by cambo3d
pmed you, so we dont hijack this thread
Posted: Sat May 11, 2013 2:12 pm
by Broose
bplemmons wrote:Anyone have some before and after, print quality pics to share?
Love to see them!!
Bill
Not quite perfect, but a big improvement. Click to zoom in. The rough part on the stock arms side I believe was where the loop starts after a retraction and move. Kisslicer staggers the start point on each layer. The other side of the Vica sculpture looks great on both prints.
EDIT:I've replaced the photo because on further inspection, the issue with the rough part on the stock arms print may have been retraction-related rather than an arm issue. The quality of the print is much improved with the magnetic arms, and this updated photo is a better comparison of print quality. Notice the better layer alignment on the magnetic arms version, which was actually printed faster.
Posted: Sat May 11, 2013 4:29 pm
by elqisqeyano
Broose wrote:bplemmons wrote:Anyone have some before and after, print quality pics to share?
Love to see them!!
Bill
That is a noticeable difference. Did you see the one I printed with stock arms, came out close to yours with the stock arms. I can't wait for my CF tubes to arrive.
Posted: Sat May 11, 2013 4:53 pm
by Broose
elqisqeyano wrote:Broose wrote:bplemmons wrote:Anyone have some before and after, print quality pics to share?
Love to see them!!
Bill
I noticed after the print that one of my cheapskates was a little loose. That could account for the few imperfections that are left in the print with the magnetic arms. I won't have access to my printer until tomorrow, and I'll try another print then.
Posted: Sat May 11, 2013 5:04 pm
by elqisqeyano
Check those cams, make sure they are tight. I had the same problems cause I forgot to tighten down the Cams. Once tight cheapskates were firm, no wiggle.
Posted: Sat May 11, 2013 9:51 pm
by bplemmons
Broose, Nice work, What arms are you using?
Posted: Sat May 11, 2013 10:14 pm
by sheepdog
This is a fantastic mod from the pictures I have seen, excellent job.
Posted: Sat May 11, 2013 11:03 pm
by xnaron
Love to see them!!
Bill
Looking good! What hot end are you using?
Posted: Sat May 11, 2013 11:06 pm
by xnaron
Here are some pics of my new quick change extruder setup...
I'm using a 5.2:1 geared nema 17. I am set to 60mm/s retracts and the Rambo current is set at 115. I think I can go even faster on the retracts. To change the filament you just push the two long springed screws down and pull the bearing piece forward. It is super quiet! These are the extruders I use on all my other printers like the Behemoth. A little pricey though as the stepper and gear are about $50 to $60. For me it is well worth the price. I have hundreds of hours of use on these and they just keep on going and going.
In the pics you can see I put the hole in the wrong spot for the bowden tube on the laser cut piece. Doh!
The files are up on my github
https://github.com/xnaron/Xnaron-Magnarms-for-Rostock
Posted: Sat May 11, 2013 11:37 pm
by xnaron
Here is a vica I sliced with KISS at .25mm layer height in Vase fill with one loop. I am getting ever so slight stringies because I have the temp a touch low. This is with the cheap reprapper.com silver PLA. It doesn't print anywhere as nice as the ultimachine silver does.
Checkout the layer alignment! These delta's are amazing!
Posted: Sun May 12, 2013 12:01 am
by xnaron
FYI
Posted: Sun May 12, 2013 3:27 am
by bplemmons
Wow, that extruder looks amazing. you are really taking the Rostock to a new level..
Can you share your source for the stepper?
Thanks for sharing your amazing upgrades!!
Bill
Posted: Sun May 12, 2013 4:58 am
Xnaron: Please read your PM's.
Posted: Sun May 12, 2013 9:00 am
by Broose
xnaron wrote:Broose wrote:bplemmons wrote:Anyone have some before and after, print quality pics to share?
Love to see them!!
Bill
I'm using an E3d all metal hot end with a .4mm nozzle
Posted: Sun May 12, 2013 5:10 pm
by xnaron
Because there are too many Yoda's...
Printed at 200mm/s in 45min. It is 100mm high.
Posted: Sun May 12, 2013 7:00 pm
Xnaron: Would it be possible for you to post the squirrel cage fan mounts that you created to hold those squirrel cage fans
you are using?
Posted: Sun May 12, 2013 7:24 pm
by elqisqeyano
xnaron wrote:Because there are too many Yoda's...
Wow.
