Page 8 of 33
Re: Delta Automatic Calibration Tool - For Repetier Firmware
Posted: Sun Aug 02, 2015 12:44 am
by RollieRowland
I haven't had a chance to test on Windows 7, although I did try a couple things that may help:
https://drive.google.com/file/d/0B06WCA ... sp=sharing
Also, this version is not ripped from my debugging folder like the previous ones. If this doesn't work then I would recommend installing .Net Framework 4.5.2. Which is a requirement for the app
Posted: Sun Aug 02, 2015 9:16 am
Installing now, note that the installer automatically detected and installed .Net FW 4.5.2 on my Windows 7 box.
However, I still run into the same problem when running it.
Posted: Sun Aug 02, 2015 9:18 am
by duvdev
Hi
About the fat kit. I will order it now. It there any spacer or any plastic part that I need to print?
Do I have to configure the board or just to connect it to the rambo?
Thanks
Posted: Sun Aug 02, 2015 9:44 am
duvdev, PLEASE follow the link I posted in this thread a day ago. There is lots of information about mounting FSRs on the web - the google delta group has the majority of it since that is where Johann posted his initial FSR design. But, several of us post here too so you can simply search and learn everything you need.
I strongly suggest that you do some reading - I even posted links to the details on the board that describes how to configure and use it - click it!
How Will Adjusting Diagonal Rod Length Effects Part Dimensio
Posted: Mon Aug 03, 2015 5:18 am
by Pyropainter
Good Morning
I have just finished using your manual version for calibrating my Rostock Max v2 and am very happy with the results, even though I have not yet tried to print anything. Thank you for investing your time in something that is sure help many others. I have been thru this thread and not found an answer to the following concern and questions. If I have overlooked it. Please send me in the right direction. While performing the calibration I remembered reading that one way to improve printed part dimension inaccuracies is to change the diagonal rod length and noticed that changing it is required when using your manual calibration program. I do have a couple of questions if you do not mind. First, does your program some how adjust the other parameters to compensate for the changes made to the diagonal rod parameter that will correct the inaccuracies? Second, If not how do I correct them. I assume that the only option would be scaling the stl in a slicer.
Thanks again.
Re: How Will Adjusting Diagonal Rod Length Effects Part Dime
Posted: Mon Aug 03, 2015 7:28 pm
by RollieRowland
Pyropainter wrote:Good Morning
Thanks again.
At the moment you may get inaccuracies in the XY dimensions IF your printers frame is not square. I do not have a fix for this currently, however, I am looking into using inductive proximity sensors to correctly find the delta radii offsets (move towards tower until the sensor triggers). This would still not entirely fix the issue, that relies entirely on your frame. If the diagonal rod is changed more than 0.3 +/-, I would consider measuring your rods or rebuilding your frame. Otherwise this will not cause a significant change in the XY dimensions.
Also, sorry mhackney, I will try to find a fix soon but I haven't had time.
Posted: Mon Aug 03, 2015 7:34 pm
No worries, I'll keep my eye out for it. If there is anything I can do to help, let me know. As you probably may know, I'm a software guy by profession and know most languages and platforms well enough to be dangerous.
Posted: Wed Aug 05, 2015 2:09 am
by crocky
FSR wiki has useful information too,
http://reprap.org/wiki/FSR on how to hookup...
Posted: Wed Aug 05, 2015 2:24 am
by duvdev
So just to make it clear the app will be able to work with z probe ? Because I don't have a of fsr now
Posted: Fri Aug 07, 2015 1:14 am
by Jrjones
So far I'm up and running after using Rollie's v1.03 of the HTML calibration calculator, and my largest deviation is 0.12mm (of 169 measured points, 8 points are 0.10mm or greater.)
I haven't noticed any discrepancies in X and Y or Z measurements, I scale my parts by 1.6% to account for ABS shrinkage in the X and Y directions.
I'm happy I can relax a bit about watching the first layer to make sure it adheres properly.
I may run it again with my second dial indicator to see if that improves it at all (my easy to read digital indicator is +/- 0.0254mm, my old analog one is +/- 0.0025 I believe).
But for now I am leaving it as is because I can successfully print larger objects than 60mm!
Posted: Fri Aug 07, 2015 10:19 am
by RollieRowland
duvdev wrote:So just to make it clear the app will be able to work with z probe ? Because I don't have a of fsr now
Yes, this should work with both.
jrJones wrote:So far I'm up and running after using Rollie's v1.03 of the HTML calibration calculator, and my largest deviation is 0.12mm (of 169 measured points, 8 points are 0.10mm or greater.)
On your last calibration, what was your measurements of the 6 outer points? Also, how many iterations did you run?
Glad it has helped!
Posted: Sat Aug 08, 2015 10:58 pm
by DGBK
I wanted to update that after getting a longer bowden tube, I have had pretty good success using v1.03 with manual calibration (adjusting the z height with the lcd and using paper). My calibration is about as good as I will get it manually. I've been getting much better prints since implementing your leveling aid. I have some FSRs on order, so I will be able to get a more accurate calibration and hopefully take advantage of the automatic version of the program.
Thanks a lot for your work.
Posted: Sun Aug 09, 2015 12:37 am
by RollieRowland
DGBK wrote:I wanted to update that after getting a longer bowden tube, I have had pretty good success using v1.03 with manual calibration (adjusting the z height with the lcd and using paper). My calibration is about as good as I will get it manually. I've been getting much better prints since implementing your leveling aid. I have some FSRs on order, so I will be able to get a more accurate calibration and hopefully take advantage of the automatic version of the program.
Yeah, I just installed my FSRs around 4am yesterday. I do need to drop the z-probing speed to improve accuracy (added to the list for 2.0.1). With the current speed - which I think is 60mm/s - it only gives an accuracy of +/-0.075 in three iterations. I am hoping to get a lot done on this in the next day or two.
You're welcome!
Posted: Sun Aug 09, 2015 4:39 am
by crocky
Still waiting for mine to arrive, they are in Melbourne according to tracking... So maybe tomorrow, or tuesday.. I am designing new FSR pads to go into the holes where the bolts go, line up should be a breeze.
Posted: Sun Aug 09, 2015 12:47 pm
I just dug out a Windows 8 laptop that I'd been using on my Droplit printer to try this calibration code on. As soon as this print is complete, I'll give it a shot.
Posted: Sun Aug 09, 2015 1:43 pm
No glory, this was a windows 7 laptop and it failed exactly the same as windows 7 VM on my Mac. I don't have windows 8.
Posted: Sun Aug 09, 2015 8:19 pm
Ok, it turns out my son has a laptop with Win 8 that he got for college last year. So I can now give it a shot. However, I have FSRs so the homing speed may be an issue.
Posted: Mon Aug 10, 2015 1:35 am
by eigenbot
This was super helpful in leveling my first layer for large surfaces - thanks!
I've read through most of this string, and it seems like you're going more towards an automated system than the g code direct entering, but since I'm running with pretty basic tools I have a couple comments about running it manually with the .html file in your zip. Sorry if I missed something earlier in the thread!
I'm using the new carriages, and I think increasing the horizontal radius to 140 makes the lest position of x0 y-130 outside of the print boundaries. I ended up doing mine manually because I could get the paper test to be more consistent than trying to rig up the callipers so I just changed my G code for that line. I ended up changing to a radius of 126 instead of 130 because my z-axis bottomed out at z=0 for anything larger at the opposite z tower - but the algorithm still really improved my large first layer printing.
Also, the G code maths? If the radius is 130, the y corners should be at +\- 65 rather than 63.
Again, thanks for such a handy tool and I super appreciated the diagrams about how each dimension affects the towers!
Posted: Tue Aug 11, 2015 12:06 pm
by RollieRowland
mhackney wrote:Ok, it turns out my son has a laptop with Win 8 that he got for college last year. So I can now give it a shot. However, I have FSRs so the homing speed may be an issue.
I am getting close to having 2.0.1 finished, the probing speed will be adjustable but will be initially set at a lower speed so all z-min endstops work properly/accurately.
eigenbot wrote:This was super helpful in leveling my first layer for large surfaces - thanks!
Thank you for pointing out the error in the gcode that I was using, I made the correction in the original post. I'm glad that it's helped you so far!
Posted: Tue Aug 11, 2015 12:49 pm
Were you able to add a "let's figure out how tall the z probe is" feature?
Posted: Tue Aug 11, 2015 2:33 pm
by RollieRowland
geneb wrote:Were you able to add a "let's figure out how tall the z probe is" feature?
Yes, I am still implementing it though. One thing to take note of is that it does require the z-height to be set first.
Posted: Tue Aug 11, 2015 3:58 pm
Ok, cool. The Z height set is the simple part and something most people should have a handle on how to do already. I'm just thinking it would be cool to have a "redneck" z-probe that you can just slap on and go.
Posted: Tue Aug 11, 2015 4:21 pm
by bvandiepenbos
RollieRowland wrote:geneb wrote:Were you able to add a "let's figure out how tall the z probe is" feature?
Set z height MANUALLY to run "auto" calibration ??????
Now that is just silly.
Posted: Tue Aug 11, 2015 5:03 pm
It makes perfect sense. You have to know what the machine Z height is if you're going to try to discover how tall the z-probe mechanism is.
Posted: Tue Aug 11, 2015 7:22 pm
by RollieRowland
bvandiepenbos wrote:RollieRowland wrote:geneb wrote:Were you able to add a "let's figure out how tall the z probe is" feature?
Yeah, I can see why you think this way. The program will only truly be an automatic calibration with FSRs installed. Otherwise it is a semi-automatic calibration. This wouldn't be necessary if the z-minimum probe was the same exact height as the nozzle.
