Page 2 of 2
Re: LCD reset when heating hot end
Posted: Sat Feb 18, 2017 9:07 pm
by skyjuice
Got the board to work. Turned out to be a bad solder from the factory. I just separated the two posts and voila. Now I need to figure out why temps are reading DEF. Everything is brand new, so it has to be a connection of sorts. Thermistors were just replaced.....
Posted: Sun Feb 19, 2017 12:56 am
by Dale Eason
skyjuice wrote:The fan under the rambo does not turn on. What might I be dealing with?
skyjuice wrote:The fan for the rambo does turn on. I am pretty familiar with this board at this point and have many of the little fuses on hand (bought a roll of them) just in case
I'll check some more around the board with the ohm meter. Thanks.
First you said the fan did not work so that is why I was talking about it.
I am glad you are making progress.
Dale
