Page 2 of 3
Re: TRAILtech's Rostock Build
Posted: Thu Jul 25, 2013 11:47 pm
by TRAILtech
Yup thats my first cube!
I've been reading the link you sent me, but i can't figure out how to get my printer to only do a single layer?
I'm using slicer, I tried putting a 0 in the Infill but it didn't just print a single layer for my perimeter...
Posted: Fri Jul 26, 2013 3:06 am
by kbob
Set the infill to zero, as you said. Then set the number of perimeters to 1. (Print -> Layers and Perimeters ->Perimeters (minimum))
Posted: Fri Jul 26, 2013 2:57 pm
by Flateric
Infill not touching the edges on all sides is generally related to one of your arms not moving perfectly smoothly and binding or rubbing slightly.
But an excellent first print IMO. Perhaps slightly too much plastic being extruded. Do polygonhell's extruder calibration proceedure.
Posted: Sun Jul 28, 2013 4:13 pm
by foshon
I'll respectfully disagree with Flateric here, try setting your top infill setting under advanced to 250% and see if it gets better. I had my arse kicked by this for awhile even after installing the carbon arms.
Posted: Tue Jul 30, 2013 10:30 pm
by TRAILtech
Alright gentlemen, so I disassembled my delta arms and belts / checked for smoothness on all connections (including the cheepskates on the rails). I also changed my top fill to 100%. I'm glade I did both, the cheepskates were not moving very smoothly.
The following are photos of the cube I printed with top infill set to 100%
[img]http://i42.photobucket.com/albums/e308/mxpxer7/photo13.jpg[/img]
[img]http://i42.photobucket.com/albums/e308/mxpxer7/photo14.jpg[/img]
The top layer looks pretty good, however the bridge looked awful.. So i dialed my extruder multiplier down to .85
[img]http://i42.photobucket.com/albums/e308/mxpxer7/photo11.jpg[/img]
[img]http://i42.photobucket.com/albums/e308/mxpxer7/photo12.jpg[/img]
You can see some separation between the infill and the Inner perimeter. I'm going to bring my multiplier back up to 0.95 .
Any ideas on reducing all the sag and spaghetti on the bridge portion of the cube? Do i need more fans?
Posted: Tue Jul 30, 2013 10:39 pm
by TRAILtech
Also, just ordered my assembled TrickLazer arms... Hope that wasn't irrational. lol
Posted: Wed Jul 31, 2013 4:46 pm
by lordbinky
If you use Slic3r there is advanced settings for bridges to increase the movement speed, which may help you.
Upgrading the arms? It's irrational not to!
Although I'm going the dumbass way and doing it myself.
Posted: Wed Jul 31, 2013 7:09 pm
by foshon
Try 200% for top layer infill, it will do a better job of filling the holes.
Posted: Thu Aug 01, 2013 12:59 pm
lordbinky wrote:If you use Slic3r there is advanced settings for bridges to increase the movement speed, which may help you.
Not so dumbass, you can save a lot of money. Either the Xnarron type magnetic or the Traxas links, they are both inexpensive
compared to what is commercially available.
Posted: Thu Aug 01, 2013 4:46 pm
by lordbinky
Yeah... hopefully the feeling of accomplishment adds a similar time back to my lifespan that the stress takes off when I'm sitting in a pile of parts
Posted: Fri Aug 02, 2013 12:12 am
by TRAILtech
weeelll damn.. My themistor came loose and I melted my f-ing hot end.
[img]http://i42.photobucket.com/albums/e308/mxpxer7/photo15.jpg[/img]
opinions on upgrades? J-Head, E3D ?
Posted: Fri Aug 02, 2013 12:49 am
by Flateric
Been there done that.
Sucks, but now is the time to get either a nice jhead or a e3d.
Posted: Fri Aug 02, 2013 2:33 am
by JohnStack
flateric ibid. E3D.
Posted: Fri Aug 02, 2013 5:25 am
Trailtech, I can imagine the sickening feeling in your stomach when you saw that.
I feel for you but let's try to learn from this and make sure it doesn't happen again.
This link is for the screw-in thermistor that fits a 3mm threaded hole.
http://www.ebay.com/itm/Modular-Screw-o ... 4ac6f1ca4f
You will need to invest in a 3mm tap and possibly a 2.5mm drill bit, but once you screw that sucker in it's gonna stay in. IMO this is one of the best investments you could make.
Match this part with a j-head or E3D. The choice of hotend would be driven more by what you print, if it's PLA the J-head excells. For ABS the E3D excells.
I just purchased the E3D because of how it is made and you can bet it will have a threaded thermistor.
Posted: Fri Aug 02, 2013 12:10 pm
by TRAILtech
It sure was a tragic sight. Thank you guys for the input, the E3D looks badass... Only problem is there's a 4 week lead time! No bueno. I ordered a J-Head, i'll probably order the E3D next.
Also, that screw in Thermistor looks excellent! Ordering one right now.
Posted: Sun Aug 11, 2013 3:50 pm
by TRAILtech
Okay so I have a J head hotend now... The problem is that it doesn't have any fancy connector for my tube which routes the printing material, any suggestions?
[img]http://i42.photobucket.com/albums/e308/mxpxer7/photo.jpg[/img]
Posted: Sun Aug 11, 2013 4:19 pm
- x2scrap.png (160.89 KiB) Viewed 20714 times
If you can print either of these they will work to hold the J-Head and accept a Bowden fitting.
Or perhaps get a friend to print one for you.
Posted: Sun Aug 11, 2013 7:14 pm
by TRAILtech
None of my friends are cool enough to have a printer
I just ordered the mount from tricklazer. I'm excited to get printing again, since the melt down I've purchased the J-head, Threaded thermistor, and carbon fiber arms.
What I want to do next is figure out a way to get away from using belts. I want to use cable
Posted: Sun Aug 25, 2013 11:26 pm
by TRAILtech
Okay i need some serious help!
I have installed the J head, and delta arms fully. I can't get any filament out of the nozzle.
It comes out in little beads, and then the printer head jams up. I have the original peek fan blowing on the barrel of the j head. I'm heading the head up to 198 C printing PLA plastic. The nozzle diameter is .4mm . I changed it in repetier so it knows, the extrusion multiplier is set at 1 for now.
Any suggestions? Higher temperature? lower extrusion rate?
Posted: Sun Aug 25, 2013 11:56 pm
Given the picture I'll guess it's a JHead copy rather than an original from hotends.com?
Some of the Chinese copies are unusable because the nozzle orifice is too long, the first thing to try though is printing hotter, I'd go as high as 230 for PLA depending on the vendor and the color.
Posted: Mon Aug 26, 2013 9:48 pm
by TRAILtech
Now your scaring me, I ordered it from Makergeeks.com ...
Posted: Mon Aug 26, 2013 11:02 pm
TRAILtech wrote:Now your scaring me, I ordered it from Makergeeks.com ...
This is Brian's piece on copies
http://jheadnozzle.blogspot.com/2012/12 ... lones.html
Several people on the reprap forums got unusable copies which is what prompted the piece.
Posted: Sun Sep 01, 2013 5:11 pm
by TRAILtech
Bummer : (
I'm looking at the E3D hotend now, since hotends.com doesn't have any of the J-heads in stock. What will I need to mount the E3D? I have the kit for the J-head, do you think it'll work wiht the E3D?
Posted: Sun Sep 01, 2013 6:45 pm
by lordbinky
It will, until you decide to print your own mount
and good news E3D's are shipping quickly now. Yay.
Posted: Sun Sep 01, 2013 7:11 pm
by TRAILtech
alrighty then its on its way!
Can someone pleaaase post Repetier settings for printing PLA with the E3D?
It feels like an eternity since I've actually printed anything successful
