.83 Repetier Problem
Lochemage
Re: .83 Repetier Problem
Post by Lochemage »
MSURunner wrote:No, it doesn't reset it's height after receiving a G28 when in code. It resets itself if it's given JUST a G28, but if there's more than just the G28, it bores to China. Check out that first video...
As I recall, there is a section in the Rostock MAX build manual that states in large bold letters a similar issue:
[img]http://i.imgur.com/tMvjqHq.png[/img]
If using the Home X or Y buttons actually issue's a G28 with X or Y parameters filled in, then this would be the same reason why yours is doing that too..
- Lochemage
MSURunner
Post by MSURunner »
Well the issue arose from attempting to print from the SD, so I don't think that's the case. Regardless, I tore through the wiring harness to see if there was some sort of issue there and attempted to clean up the spaghetti mess of wires. Plugged everything back in and it works now. All I can think of is there was some sort of residual value stored away somewhere in the board that disconnecting all power to it caused it to reset. Weird...
lordbinky
Post by lordbinky »
The good ol' unplug-replug fix. There are many times I've made sure to do a few extra good deeds when that fix works.
MSURunner wrote:Well the issue arose from attempting to print from the SD, so I don't think that's the case. Regardless, I tore through the wiring harness to see if there was some sort of issue there and attempted to clean up the spaghetti mess of wires. Plugged everything back in and it works now. All I can think of is there was some sort of residual value stored away somewhere in the board that disconnecting all power to it caused it to reset. Weird...
Congratulations on getting it fixed. You will never know for sure what caused it which is a shame but now IT WORKS!!! :)
