Page 2 of 3
Re: 3D Printed Enclosure Mounts
Posted: Tue Dec 31, 2013 2:24 pm
by bubbasnow
This thing is getting pretty popular, it just made an appearance on the Seemecnc facebook! Cope you should post your changes so people don't use a unimproved model.
Posted: Wed Jan 01, 2014 4:30 pm
by TFMike
How could the Orion be modded to have the spool holder on top and this thing downsized? Anyone up to try it?
Posted: Thu Jan 02, 2014 12:31 pm
by jmpreuss
TFMike wrote:How could the Orion be modded to have the spool holder on top and this thing downsized? Anyone up to try it?
I have my spool top mounted on my Orion, there is a post about it in that forum. Note it was easier for me since I had a pre-production that had screw holes for a top mount, most others would need to drill holes. SeeMeCNC posted the design files for the top mount on their orion github site.
Posted: Thu Jan 02, 2014 12:55 pm
by int2str
I have a very easy idea for an ORION "enclosure".
The "prototype" is on my printer that's currently running.
With an ambient temperature of 20C, temperature inside the "enclosure' is around ~30C. I think that'll help with the part cool-down and hopefully prevent some ABS layer separation as it cools.
I'll try to clean up the prototype a bit going into the weekend and I'll make a post about it.
Posted: Fri Jan 03, 2014 1:40 pm
by cope413
bubbasnow wrote:This thing is getting pretty popular, it just made an appearance on the Seemecnc facebook! Cope you should post your changes so people don't use a unimproved model.
I've been slammed lately with the holidays, outside print jobs (including a massive one that I'll post pics of soon), prepping for
http://www.3dprinterworldexpo.com/page. ... ch=5120_94, on top of my normal day job.
Haven't been active much, but I'll catch up with the forum activities soon...
Posted: Fri Jan 03, 2014 5:06 pm
by TFMike
int2str wrote:TFMike wrote:How could the Orion be modded to have the spool holder on top and this thing downsized? Anyone up to try it?
Awesome, got pictures? Also did you see the private message I sent you awhile back?
Posted: Fri Jan 03, 2014 11:46 pm
by bubbasnow
this design linked should also work for the orion, although i do not have one so it is not tested
Posted: Sat Jan 04, 2014 4:01 pm
by TFMike
the orion is like a round triangle shape while the max is a circle at the base, right?
Posted: Sat Jan 04, 2014 5:54 pm
by bubbasnow
TFMike wrote:the orion is like a round triangle shape while the max is a circle at the base, right?
true, but this mounts to the arms using the 120deg angles. it should work, if not the idea should work and need to be scaled down a bit. but like i said i dont have one so i dont want to say for sure. from the pictures on the seemecnc website it should work.
Posted: Sun Jan 05, 2014 6:45 pm
by bubbasnow
finished my latch today
[img]
https://lh6.googleusercontent.com/-myg0 ... 163110.jpg[/img]
[img]
https://lh4.googleusercontent.com/-Rsh5 ... 163122.jpg[/img]
[img]
https://lh6.googleusercontent.com/-Zkx8 ... 163138.jpg[/img]
the hinge axis are 6 inches, print 4 square pins, 6 round pins, 3 arms, 4 ea front and back latch. i would scale the pins x.99 or x.98.
the color change is kind of lame, but my clear t-glase was boning up. green printed way better!
Posted: Sun Jan 05, 2014 7:27 pm
One more time, Damn good job! This is something that could be made into a kit and sold for profit...
There are so many print hours in it though.....
The panels the buyer would pick up local.
Posted: Sun Jan 05, 2014 7:37 pm
by bubbasnow
it was a little over 1 roll of pla. if we think of it in those terms it doesn't sound that long
I've printed about 6 rolls since i started printing in September not counting this. this print (besides the latch) doesn't require anything fine in detail so a .7 nozzle would do this in no time.
Posted: Mon Jan 06, 2014 8:07 pm
by cjdavis618
This enclosure is Fan..Freaking..tastic..
Great work!!!
Posted: Wed Jan 22, 2014 8:34 am
by enggmaug
Only one door ? Isn't it an issue for maintenance, calibrating and cleaning ?
Posted: Wed Jan 22, 2014 10:01 am
by bubbasnow
I've taken my heat bed out with no issues. You could always add more doors if you want. To adjust end stops I have knobs installed so I can adjust by hand.
Posted: Wed Jan 22, 2014 4:04 pm
by enggmaug
bubbasnow wrote:To adjust end stops I have knobs installed so I can adjust by hand.
I see. Great work !
Posted: Mon Feb 03, 2014 3:33 pm
by Capt Jack
I want to print this enclosure (bad!), but I can't open/modify .sldprnt files. Can you possibly post the joint file in .stl format?
Posted: Tue Feb 04, 2014 5:07 pm
by Capt Jack
Nevermind. Got the 15 day trial of eDrawings and converted it.
Posted: Wed Feb 05, 2014 12:38 am
by bubbasnow
sorry i spaced out for a couple days... if you need it in a different cad format let me konw.
Posted: Fri Feb 07, 2014 2:18 pm
by grabredemeyer
Did Cope end up posting his changes/improvements to this somewhere? I'd like to see what he did before I print a version of this.
Posted: Fri Feb 07, 2014 7:08 pm
by bubbasnow
grabredemeyer wrote:Did Cope end up posting his changes/improvements to this somewhere? I'd like to see what he did before I print a version of this.
not that ive seen
ive been using these since this post started with no issue printed as is. only issue that i saw that could be improved upon is support where the screws go through into the wood. because not everyone would put screws in the same place i left that up who ever wants/needs to put them in.
Posted: Sat Feb 08, 2014 4:32 pm
by Capt Jack
How did you print the joints? Specifically, how did you lay them out on the print bed....horizontal or vertical? Just looking for the best way to print them.
Posted: Sun Feb 09, 2014 3:53 pm
by bubbasnow
Capt Jack wrote:How did you print the joints? Specifically, how did you lay them out on the print bed....horizontal or vertical? Just looking for the best way to print them.
vert hollow 3 perimeters
Posted: Sun Feb 09, 2014 6:12 pm
by Capt Jack
bubbasnow wrote:Capt Jack wrote:How did you print the joints? Specifically, how did you lay them out on the print bed....horizontal or vertical? Just looking for the best way to print them.
Posted: Wed Feb 12, 2014 1:52 pm
by dansch
wow, real great work! i was looking for a way how to prevent my rostock from becoming to dusty (in my workshop), and this seems like the perfect solution!
