Re: Clogged Nozzle???
Posted: Thu Jun 05, 2014 10:02 pm
Batteau62 wrote:I been thinking about this one. Here is as good a thread as any to discuss it. Ok with you Capt Jack?
Here is the idea![]()
I haven't researched fits, but I'm thinking of taking a helicoil (or the like), threading it onto the PTFE tube, then source or make a fitting that allows you to attach one end to the helicoil and the other to whatever fitting male/female is needed at the hotend or extruder. I think the helicoil wouldn't be a problem? It's the fittings for it I'm not to sure about? It would need to be like a hose fitting, allowing you to tighten it on without imparting twist in the tube.
Thoughts, constructive criticisms and discussion welcome.
so..... something like this:
http://www.mcmaster.com/#standard-threa ... ts/=sa7hx2
OR
http://www.mcmaster.com/#standard-threa ... ts/=sa7hm4
PLUS THIS:
http://www.mcmaster.com/#standard-tube- ... rs/=sa7iqa
and maybe a collet/other two part thing to squish them together and make sure they dont come apart? Thinking along the lines of: http://www.thingiverse.com/thing:61729
