How to adapt the ATX PSU for Rostock MAX
Re: How to adapt the ATX PSU for Rostock MAX
I try to avoid the painfully obvious. :)
dtgriscom
Post by dtgriscom »
geneb wrote:Remove the four nylon screws from the power supply and push it back a bit. It will drop out of the hole in the bottom plate...like it was designed to.
whooops... missed that one... thanks...
geneb wrote:I try to avoid the painfully obvious. :)
There was one message from a user who said you had to remove the bottom plate to get it out so what is obvious to you (because of your experience)
is not so obvious to some who do not share your experience level or your acute common sense. Wouldn't hurt to add a line to the manual that mentions
power supply removal.
Eagle, the power supply hovers over a HUGE hole. It's supported in the front by the four nylon mounting screws and in the back by resting on the edge of the hole. If you take out the screws, the thing will likely drop on to the table with a rather noticeable *THUD*.
geneb wrote:Eagle, the power supply hovers over a HUGE hole. It's supported in the front by the four nylon mounting screws and in the back by resting on the edge of the hole. If you take out the screws, the thing will likely drop on to the table with a rather noticeable *THUD*.
That does sound rather obvious. If they can't figure that out they probably shouldn't be building kit printers. Thanks, Gene or should we call you Conan?
YARGH! :D
You know, I bet I could make a killing if I made a set of Philips screwdrivers with "Pointy End Towards Screw" engraved on the shank. :D
geneb wrote:YARGH! :D
You would have to have it in five different languages.
lordbinky
Post by lordbinky »
Plus one line using symbols, for universal appeal, like on coffee cups.
