Page 2 of 2
Re: Free $150 from Misumi for first time customers
Posted: Sun Mar 30, 2014 10:57 pm
by Eric
Barefoothurst wrote:Check this out. I think it's the same but I haven't checked the exact specs.
http://us.misumi-ec.com/vona2/detail/110300465870/?rid1
No, that stuff is 15mm x 15mm, same as Openbeam. It's what the mini-kossel uses. You could make a max-sized machine from it, but it wouldn't be as stiff.
The Rostock Max clearly uses a larger size, since it uses T-nuts, not sure exactly which. I don't own a Max to check.
Posted: Sun Mar 30, 2014 11:06 pm
by JD79
I want to say it falls into the 2525 extrusion. I'm going by the 1 inch size that is being sold on seemecnc.com parts section.
Posted: Mon Mar 31, 2014 12:39 am
by Barefoothurst
Sorry for the bad info. I'm new and still learning all I can.
Posted: Mon Mar 31, 2014 9:12 pm
by brent
JD79 wrote:I want to say it falls into the 2525 extrusion. I'm going by the 1 inch size that is being sold on seemecnc.com parts section.
so, which 2525 exactly?
Posted: Mon Mar 31, 2014 10:58 pm
by JD79
when you configure on the left side choose width of 25 and thickness of 25 single row slot and then choose anodized or black anodized. Packing list for Max v2 shows t slot rail 1" (25mm) square x 32" (812mm) long. Picked it up from ups today.
Posted: Tue Apr 01, 2014 2:12 am
I'm not positive, but I think SeeMeCNC use 8020 extrusions, they have a different profile than the Mitsumi ones, you might have issues with the cheap skates.
Posted: Tue Apr 01, 2014 8:32 am
by joecnc2006
Posted: Tue Apr 01, 2014 3:51 pm
by brent
This promotion is now over. I edited the post to reflect that so people don't waste time.
Re: [ENDED] Free $150 from Misumi for first time customers
Posted: Tue Apr 01, 2014 8:46 pm
by AndThenSome09
Good idea, thanks for that! :D
