Page 2 of 2
Re: Mach 4-Axis Board Configuration
Posted: Thu Jun 07, 2012 3:36 pm
by PartDaddy
In my "SeeMeAdmin" post above (on top of second page), The Z and A axis dip switches should be set the same, for 1/8 stepping. X and Y are set for 16th microstepping.
Posted: Thu Jun 07, 2012 8:35 pm
by mastercaster
Yup.
Went over the settings very carefully and used the slic3r settings for 3mm,.02 yoda. A little fiddling and WOW. fantstic prints on Plexiglass with ABS.. Hard to belive the print quality. Thanks for a great product.
Only thing we need is some kind of good feed system. The machine needs a little tending cause the filiment tends to jump over each other and jam.. But with a little tending no real problems.
Alan
Posted: Wed Jun 13, 2012 3:28 pm
by mtizle
Below are my Motor Tuning Profiles. They turned out to be double of that of mhackney's configs. I also had to reverse the motor direction for the correct + and - direction.
Mtizle
Posted: Wed Jun 13, 2012 8:35 pm
You probably have your 34 Axis board configured for a different micro step than I do, that's why your steps per are doubled. I think I have mine configured for 1/8 stepping. How is yours configured?
Cheers,
Posted: Thu Jun 14, 2012 12:15 pm
by mtizle
No idea what the stepping is... is that configured on the board by the jumpers? My jumper settings came from Steve's with Seemecnc. So you think it could be set to 1/16 micro step right now?
Mtile
Posted: Thu Jun 14, 2012 12:27 pm
by johnoly99
Tizle, yeah, the board you looked at up in the lobby was 1/16 stepping.
Posted: Mon Dec 31, 2012 1:33 pm
by pwaisberg
Hi,
I am curious if anyone installed limit switches? Do you have photos or diagrams? Thanks!
Posted: Wed Apr 03, 2013 6:37 pm
by Jojo
Hello
I am new to seemecnc and I have a quick question that I hope you guys can help me with. I have had a 4 axis board for a while now and I think it may be an older one because everything looks the same except my dip switch only have 2 switches per box instead of 6 as shown in your pictures. Will this affect the jumper fix? Thanks in advance.
