Don't think these will work for a V2 because of the difference in the upper bearing structure. Maybe someone can come up with an alternative solution to adjust the new structure without putting too much of a load on the front where the melamine is thinner.Eaglezsoar wrote:You should consider printing the belt tensioning devices on Thingiverse, that will enable you to put tension on whatever side you need it on to keep the belt running straight.
http://www.thingiverse.com/thing:87463
Calibrating the Cheapskates
Re: Calibrating the Cheapskates
You are correct. I didn't consider that you had a version 2. I haven't seen the V2 and I haven't seen any tensioners for it yet.dgriff wrote:Don't think these will work for a V2 because of the difference in the upper bearing structure. Maybe someone can come up with an alternative solution to adjust the new structure without putting too much of a load on the front where the melamine is thinner.Eaglezsoar wrote:You should consider printing the belt tensioning devices on Thingiverse, that will enable you to put tension on whatever side you need it on to keep the belt running straight.
