Page 2 of 2
Re: Hunin's Rostock MAX v2 Build - Elric
Posted: Sun Dec 06, 2015 11:11 pm
by Hunin
Here are 3 different views of the layer fan. I didn't get any stringing but continue to have these nodules. I'm using the stock slicer settings with PID autotune and Z height calibration. Any ideas on what I can do to eliminate them on ABS?
Posted: Mon Dec 07, 2015 1:14 pm
You don't mention what temperature you are using but you could work with the temperatures for the filament you are using. My guess would be to decrease the temperature by 5 degrees C and see if it helps to reduce the nodules.
Posted: Mon Dec 07, 2015 3:05 pm
by Hunin
Eaglezsoar wrote:You don't mention what temperature you are using but you could work with the temperatures for the filament you are using. My guess would be to decrease the temperature by 5 degrees C and see if it helps to reduce the nodules.
Sorry, still learning a lot about printing.
Nozzle temperature was 228 C and a bed temperature of 90 C. I'm using the Seemecnc Slic3r settings for ABS printing.
Posted: Mon Dec 07, 2015 4:30 pm
Experimenting with the temperatures still applies. Try a temp of 223 first and try the same print.
Reduce by 5 degrees again and try the same print again. It is best to keep a log so that when you find the correct temperature
for a specific filament record the filament manufacturer, color and the best print temp.
Wishing you luck.
Posted: Tue Dec 08, 2015 12:12 pm
FYI, you printed the wrong fan duct. :)
Posted: Tue Dec 08, 2015 12:46 pm
by Hunin
geneb wrote:FYI, you printed the wrong fan duct. :)
Thanks for pointing this out to me.
I've been using version 1.67 of the assembly guide because that is about the time when I bought my Rostock MAX v2. That guide does say to use the fan shroud I printed. I'll try printing the newer layer fan shroud too. I saw the "new" user guide with more explanation which will definitely help to fine tune the printer.
Posted: Tue Dec 08, 2015 1:05 pm
If your machine is that old (uses the two piece effector platform) then that shroud IS the right one.
Posted: Fri Dec 18, 2015 11:19 am
by Hunin
I installed PEI on the build plate following mhackney's great instructions http://forum.seemecnc.com/viewtopic.php?f=36&t=7452 I also cut out some cardboard around the printer while I can get an full enclosure. Next on the list is the layer fan shroud install, LED lights and cooling fan for the power supply.
