Re: Onyx Rev 2 24 V question
Posted: Tue Jan 20, 2015 9:47 am
Yes, I did dial it down to 20V and at first everything worked like a charm. It heated to 100°C in about 5 minutes.
But suddenly the bed only used about 7A for heating and couldn't hold the temperature.
I then took everything apart and measured the resistance of the bed: 2.7 Ohm
When I assembled everything and tried to heat it, the temperature didn't rise, so i touched it and found out that around 10cm in the middle the bed stays cold and on the outside it heats normal...
so looks like that I need a new one
