Page 2 of 2
Re: E3D Temperature 140 C Plateau
Posted: Tue Jan 27, 2015 8:44 am
by KAS
well on a positive note you're narrowing it down, on a negative note my E3D V6 should be here this week sometime :/
I'll take measurements of the resistor and thermistor before installing. At least we'll have some comparable numbers.
Posted: Tue Jan 27, 2015 12:10 pm
by dct16
Well, when trying to take apart the stock hot end, I broke the tiny little thermistor wires so that was a bust.
Eventually, I said screw it and pulled the cooling fan off the V6, and it heated up no problem. I dont see this as a long term solution, obviously. Are there settings somewhere to modulate the cooling fan?
Posted: Tue Jan 27, 2015 12:39 pm
by KAS
dct16 wrote: Are there settings somewhere to modulate the cooling fan?
No idea, To be honest I thought the E3D V6 was a drop in replacement for the stock firmware with nothing else needed besides to PID autotune.
I'm starting to see a lot of issues pop up with the E3D, of course I'm noticing it more as I purchased one as-well. Not sure if it's the popularity that's showing more issues or something changed in the quality.
I ordered from MatterHackers in CA, but the tracking show it's coming from San Juan, Puerto Rico to Kentucky. Maybe it's drop shipped, not sure....
Posted: Tue Jan 27, 2015 2:50 pm
by elmoret
DCT16, there's a ~3mm gap between the heatsink and heatbreak, right? If you assembled it with the two touching, its not gonna work.
Posted: Tue Jan 27, 2015 2:53 pm
by SanjayM
The temperature curve, and the fan-on/fan-off being what is controlling whether it gets to temp or not very much points to this not being assembled with a gap between block and sink. This is quite likely to cause damage to your machine as the top of the heatsink will get incredibly hot and start to melt things.
Please do go back to the documentation instructions and check over everything.
Posted: Tue Jan 27, 2015 3:01 pm
by elmoret
KAS wrote:No idea, To be honest I thought the E3D V6 was a drop in replacement for the stock firmware with nothing else needed besides to PID autotune.
E3D's own documentation tells you that you need to update the thermistor to match a Semitec 104GT2 in your firmware.
Posted: Tue Jan 27, 2015 4:08 pm
by dct16
Not sure how many times I am going to have to learn the lesson that I need to read instructions thoroughly. When I first assembled the hot end, I hadn't found assembly instructions and did it by pictures--no 3mm gap.
I appreciate the help, luckily I haven't damaged anything.
Posted: Tue Jan 27, 2015 5:02 pm
by KAS
Awesome, that's good to know. Hopefully it comes in this week.
Posted: Tue Jan 27, 2015 8:58 pm
by 626Pilot
KAS wrote:I'm starting to see a lot of issues pop up with the E3D, of course I'm noticing it more as I purchased one as-well. Not sure if it's the popularity that's showing more issues or something changed in the quality.
Normally E3Ds come from the UK. Maybe they sold you a knockoff? I would get a new 40W cartridge heater (they're pretty standard) and see if that fixes it.
