Page 2 of 2
Re: 3d printed PCB
Posted: Sat Jan 10, 2015 9:18 pm
Mac The Knife wrote:At .56, and at 1.51. And they're using two ceramic heaters!!!! How many times have I been told I don't need two?
You are correct now that I see the images of the hotend. That raises a good question, why are they using two? Like you I have always been told
to use one and have told other folks to only use one, now I am confused why they felt they needed two. Anyone having an idea why they used two
please jump in and let us know.
Re: 3d printed PCB
Posted: Sun Jan 11, 2015 5:25 am
by Eric
We don't have enough information. The most common 12 or 24V cartridge is 40W, but they can be found in other ratings. If they're using 20W cartridges, two may be appropriate. But even at 40W x 2, it's not an actual problem so long as the supporting electronics can handle the switching load.
Or, it may simply be that someone important thought it would look better if the hole was filled, so it was done.
Re: 3d printed PCB
Posted: Sun Jan 11, 2015 9:09 am
by teoman
If their conductive filament has high thermal capacity, it may be cooling the hot end down. They may need a very fast response from the hotend during operation.
Re: 3d printed PCB
Posted: Sun Jan 11, 2015 12:11 pm
by bubbasnow
teoman wrote:If their conductive filament has high thermal capacity, it may be cooling the hot end down. They may need a very fast response from the hotend during operation.
the conductive paste is extruded from a sepearate nozzle from the plastics
Re: 3d printed PCB
Posted: Sun Jan 11, 2015 1:08 pm
by Nylocke
I think he means they are trying to keep the conductive paste (looks like a paste driven extrusion system to me) from heating up, since it is electrically conductive its probably thermally conductive as well, and they probably don't want it heating up the plastic (PLA but the looks of it, which does have heat soaking problems) and having it soften and ruin the parts? Who really knows...
Re: 3d printed PCB
Posted: Mon Jan 12, 2015 4:32 am
by 626Pilot
I'd love one of these. You could knock off little knick-knacks in a single step, and sell them for cheap.
Re: 3d printed PCB
Posted: Mon Jan 12, 2015 9:37 am
by Jimustanguitar
I was much more impressed with the Voltera.
[youtube]http://www.youtube.com/watch?v=5YMJrhG6Aos[/youtube]
Re: 3d printed PCB
Posted: Mon Jan 12, 2015 7:54 pm
by 626Pilot
Jimustanguitar wrote:I was much more impressed with the Voltera.
Why does everyone in tech begin their sentences with "So"?
Re: 3d printed PCB
Posted: Mon Jan 12, 2015 10:42 pm
by jdurand
So...you can sync on the symbol rate of the rest of the sentence. So...just like the preamble on HDLC.
So...did that make sense?
Re: 3d printed PCB
Posted: Mon Jan 12, 2015 11:17 pm
by 626Pilot
So, no.
Re: 3d printed PCB
Posted: Tue Jan 13, 2015 7:56 am
by barry99705
It sounds better than "Umm".
Re: 3d printed PCB
Posted: Tue Jan 13, 2015 9:28 am
Um, like so yeah!
:D
Re: 3d printed PCB
Posted: Tue Jan 13, 2015 10:09 am
by Jimustanguitar
So it's like verbally writing code with a while statement.
Re: 3d printed PCB
Posted: Tue Jan 13, 2015 10:53 am
by Eric
So, why does everyone say everyone when they don't literally mean everyone?
Re: 3d printed PCB
Posted: Tue Jan 13, 2015 5:01 pm
by barry99705
geneb wrote:Um, like so yeah!
:D
No. It goes "So, umm, like ohmagod!" [Headtilt]
Re: 3d printed PCB
Posted: Tue Jan 13, 2015 10:29 pm
by 626Pilot
Eric wrote:So, why does everyone say everyone when they don't literally mean everyone?
Someone really smart said that we live in specifics, but think in generalities because it's easier and we're lazy. I suppose that explains political parties.
Re: 3d printed PCB
Posted: Wed Jan 14, 2015 8:42 am
:D
"Ermahgerd!" :D
Re: 3d printed PCB
Posted: Fri Jan 16, 2015 10:29 am
by dclarkm
It's interesting, but like a lot of the current 3D printing (on the non-commercial side) it's more of a novelty use of the technology than a practical application of the technology to any true prototyping (or manufacturing) problem that needs an alternate solution.
Not saying it's useless or a waste to develop, but it's certainly not the "killer app" 3D printing needs to explode into new markets.
Re: 3d printed PCB
Posted: Sat Jan 17, 2015 2:26 am
by 626Pilot
I wouldn't say it isn't practical. You can try PCBs in-house to see if any magic smoke is released, before ordering real PCBs that will take days to reach you.
Re: 3d printed PCB
Posted: Sat Jan 17, 2015 3:21 am
by Captain Starfish
Only the sort of PCBs that you could knock out with a Dalo pen and bottle of ferric chloride, by the looks of it. Doesn't look anywhere near the resolution required for 10 thou tracks with 5 thou separation.
Still, it's an approach that holds promise if it's refined - wouldn't it be nice to print multilayer boards with printed solid vias rather than having to drill, coat, plate, tin and mask to get the layer to layer contacts working.
Re: 3d printed PCB
Posted: Sat Jan 17, 2015 4:29 am
by 626Pilot
Captain Starfish wrote:Only the sort of PCBs that you could knock out with a Dalo pen and bottle of ferric chloride, by the looks of it. Doesn't look anywhere near the resolution required for 10 thou tracks with 5 thou separation.
I decided to spend more on components with integrated PCBs and easy wiring (I2C and SPI for example) because I don't want to get into all that stuff. I have a CNC router at home so I can mill my own double-sided PCBs, but I'd just as soon let that be someone else's problem - pay more in order to worry less.
This kind of printer would be perfect for some of the projects I've worked on. Microcontroller here, input device there, output device somewhere else, and I wouldn't have to strip wires or solder them to anything. I could print everything into a solid object that gets thrown away if anything malfunctions, or I can use a backplane design, where things plug into a bus - a printed bus. Probably with those little springy metal things that are put in contact with metal pads, the ones they use for solderless connections between components and PCBs. No solder fumes, no "ick I'm touching lead with my bare hands" feeling, no having to get out the little filter-fan I use to clean (some/most?) solder fumes out of the air. I could have four layers, eight layers, weird shapes, etc. and everything comes out as a finished product. Everything would always be printed the same. I'd never have to worry about accidentally soldering something wrong, shorting Vcc to ground, accidental solder bridges, etc. I'd still have to verify the alignment of components, but at least the possibility of mis-routing a wire would be gone.
