12v x 30A = 360 wattDeltaCon wrote:Maybe I misunderstood, Jim, but are you running the whole mikmak just on 15A?
Then why do SeeMe and most of the forumbrothers here advice a PSU around 30A?
24v x 15A = 360 watt
Very loud. I cut the 24V fan connection and connected in a motor controller so that I could slow down the fan a little.bob64 wrote:How loud is the 500w 24v meanwell? I have the 750w one and god it's so noisy.
That looks to be a good supply and on ebay it averages $80 to $90 USD.Renha wrote:what about SE-450-24 ? It's much cheaper here in Russia.
You can control either voltage or the current, not both. When the current has to be limited, it results in a reduction of the output voltage. This often is not what you want. Might as well buy either a lower voltage or higher current supply in the first place.Jimustanguitar wrote:Unless it's a current limiting supply and you can run it at full throttle without hurting anything.
Yeah, I like the Rostock a lot, but I can imagine next time I choose it will be a Western-European based brand.dcfc_sandy wrote:This is just one of the aspects I think we in Europe have to bite the bullet or bide our time...
Can you explain the differences, and why the older one is better?dcfc_sandy wrote:For the SP-750-24 rather than the newer RSP.
