Page 19 of 39
Posted: Tue Sep 23, 2014 12:30 am
by nitewatchman
If you would like to get a piece and send it to me, I will cut it for you and send it back if you can cover shipping. On-line can send it straight here.
I travel a lot so might take a few days. As a matter, I am in Houston first of next month with APTA.
nitewatchman
Posted: Tue Sep 23, 2014 12:32 am
by artexmg
nitewatchman wrote:If you would like to get a piece and send it to me, I will cut it for you and send it back if you can cover shipping. On-line can send it straight here.
nitewatchman
Hey, thank! that could work ... so, you recommend the one on the link, right?
Posted: Tue Sep 23, 2014 12:36 am
by nitewatchman
That is the one I used. There could be cheaper but I have good luck with their material.
Mine arrived flat and shiny also.
I edited the message after you replied, I will be in Houston first of October with APTA. Could bring it downtown.
nitewatchman
Posted: Tue Sep 23, 2014 12:38 am
by artexmg
nitewatchman wrote:That is the one I used. There could be cheaper but I have good luck with their material.
nitewatchman
Wow!!! I would need to buy and ship right away then!
Posted: Tue Sep 23, 2014 12:40 am
by nitewatchman
PM me and we can work it out.
Posted: Tue Sep 23, 2014 2:55 am
by Renha
nitewatchman wrote:Actually got mine from On-Line Metals
oh, they aren't sending to Russian Federation
Posted: Wed Oct 08, 2014 7:31 pm
by teoman
The PEI has arrived, thanks to critical_limit for pointing out that Amazon needs to be prodded in order to send it.
I applied it to the best of my abilities. It does not have any air bubbles in it. Atleast none that you could identify as bubbles however it does look like it is a bit dirty at places. I knew i should not have trusted it to be very clean underneath the plastic wrapping. If those are indeed bubbles they do not appear to be larger than a few microns (but many of them grouped around the same spot).
Now i have to find my dremel tool and chop of the sides. And see how it goes from there.
Posted: Thu Oct 09, 2014 2:11 am
by Renha
i have used scissors, and it was pretty o'k =)
AND, I have got aluminium 10mm plate! Wonderful results on 110C at thermister! No sanding requied! Thank you all!
Posted: Thu Oct 09, 2014 2:58 am
by artexmg
Renha wrote:i have used scissors, and it was pretty o'k =)
Hey Renha, were did you get your aluminium if I can ask? thanks!
Posted: Thu Oct 09, 2014 3:19 am
by Renha
artexmg wrote:were did you get your aluminium if I can ask? thanks!
It was a gift from my brother, who worked at aerocraft corporation and have it created there. I know it's not useful info, but what could I say
Posted: Thu Oct 09, 2014 3:21 am
by artexmg
Renha wrote:artexmg wrote:were did you get your aluminium if I can ask? thanks!
By any chance your brother isn't flying to texas in the coming weeks? It is customary to bring a plate of Aluminum 10mm here in Houston
Posted: Thu Oct 09, 2014 11:58 am
by teoman
He is in Russia
So that would be a very pleasant surprise.
Posted: Thu Oct 09, 2014 1:00 pm
artexmg wrote:Renha wrote:artexmg wrote:were did you get your aluminium if I can ask? thanks!
Also a case of Bud lite!
Posted: Thu Oct 09, 2014 1:02 pm
by artexmg
True! In exchange, he will get back a case of Shiner Bock (
http://en.wikipedia.org/wiki/Spoetzl_Brewery)
Posted: Sat Oct 11, 2014 5:36 pm
by teoman
Printing a finger on its tip.
The blobbing on the right, i will deal with later. As i just printed a heat calibration tower probably forgot the retract settings or something.
I was previously printing abs at 232 degrees. Now i am down to 214.
So far so good. I sure do hope that the finger doesnt topple over creating a mess.
Posted: Sat Oct 11, 2014 5:41 pm
by artexmg
teoman wrote:Printing a finger on its tip.
Nice Adherence!
Posted: Sat Oct 11, 2014 5:43 pm
by teoman
Reminds me...
I should setup my print start automatic nozzle wiper...
Posted: Sat Oct 11, 2014 5:47 pm
by teoman
Thanks!.
So far i am very very happy with the pei. I may have a very tiny spot in the middle where i readjusted the Z height and left the hot nozzle standing there. But nothing major.
My isopropyl alcohol wipes did not arrive yet. So i wiped the bed down with acetone.
We shall see how the print ends.
Posted: Sat Oct 11, 2014 5:55 pm
by artexmg
BTW, how did you paste the PEI to the glass? I put line by line by line of the 3M strip
I don see any of the lines in the picture, is it just that cannot be seen?
Posted: Sat Oct 11, 2014 5:59 pm
by teoman
I bought the the big piece of tape.
I know line by line would have been cheaper. And may infact be better for bubble avoidance. But at the time i thought a single piece would be better and made the purchase. I have no idea why the big sheets cost so much more per cm^2 than the strips.
Posted: Sat Oct 11, 2014 6:07 pm
by teoman
Oh dear. It failed.
Well i was asking for a lot. And i do not have the other settings tuned yet. So probably insufficient Z lift and retract.
Posted: Sat Oct 11, 2014 6:15 pm
by artexmg
teoman wrote:I bought the the big piece of tape.
Oh, I see!
Posted: Sat Oct 11, 2014 6:21 pm
by teoman
I am noticin some delamination now :@
Posted: Sat Oct 11, 2014 6:26 pm
by artexmg
teoman wrote:I am noticin some delamination now :@
My quick recipe to deal with lamination (sure you know that already!)
Pump up the heat and block the "wind" using cardboard.
Post it to fails
Posted: Sat Oct 11, 2014 8:28 pm
by teoman
I was talking about pei delamination.
But i got the finger printed. Pei held untill the end.
