Page 3 of 17
Posted: Tue May 10, 2016 8:56 am
If memory serves, you send three different G codes to calibrate the printer and the results are stored in the firmware.
Posted: Tue May 10, 2016 9:00 am
by guanu
gene is correct... endstop offsets, horizontal radius, and z height are the 3 caliibration commands.. we are having it in a macro because we also tweak the acceleration before and put it back to normal after so we can get a nice fast hit to trigger the accelerometer.
Posted: Tue May 10, 2016 10:53 am
by Mac The Knife
Have all of the first order shipped?
Posted: Tue May 10, 2016 10:57 am
by U.S. Water Rockets
guanu wrote:gene is correct... endstop offsets, horizontal radius, and z height are the 3 caliibration commands.. we are having it in a macro because we also tweak the acceleration before and put it back to normal after so we can get a nice fast hit to trigger the accelerometer.
Cool! Thanks.
Does the accelerometer connect to the Rambo, or do you have a uC reading the accelerometer and then sending a signal to the RAMBo via an endstop? If there's a separate uC involved, can the firmware be modded easily?
Posted: Tue May 10, 2016 11:30 am
by Mac The Knife
Mac The Knife wrote:Have all of the first order shipped?
Just received my notification,,,, Signature required, so I had it redirected to my workplace.
Posted: Tue May 10, 2016 11:33 am
by guanu
It communicates to the rambo via I2C, not endstop like most use. The firmware has been heavily modified (I wrote the calibration gcode commands, they were not in there) and the accelerometer init stuff was added by ultimachine. We have been working on a one for all firmware, so our eris firmare has all the settings for rostocks and orions in it, and its just a few variables in the config that need to be changed to say what board and what printer you are using so it knows the dimensions and stuff.
Posted: Tue May 10, 2016 11:39 am
guanu wrote:It communicates to the rambo via I2C, not endstop like most use. The firmware has been heavily modified (I wrote the calibration gcode commands, they were not in there) and the accelerometer init stuff was added by ultimachine. We have been working on a one for all firmware, so our eris firmare has all the settings for rostocks and orions in it, and its just a few variables in the config that need to be changed to say what board and what printer you are using so it knows the dimensions and stuff.
Just wanted to thank you for an excellent job and also thank the rest of the crew who had a hand in getting this up and running.
I know that you will come out with an accessory for the Rostock Max and I will be patient. Again , THANKS!
Posted: Tue May 10, 2016 11:48 am
by guanu
Thanks Eagle, to get all the machines done on time me and JJ pulled an all nighter thrusday night to build machines. I was clocked in from 7am Thursday morning till about 7:30am Friday morning lol. Now I'm running a test print on every machine before they get boxed up.
Posted: Tue May 10, 2016 12:44 pm
I was afraid you were going to day that. When I built my Rostock Max V2, I added a pair of extra wires from the base to the top for future expansion, I used them for LED lighting. It looks like I will have to add additional wires or give up some of the LED options I added.
Actually, this gives me an idea. If the accelerometer is on a specific I2C address then I can repurpose my LED light wires as I2C wires and talk to the accelerometer over those wires and then add an I2C expander at another I2C address and use that to control lights.
By any chance, does ERIS have endstop switches at all, or do you use the accelerometer to sense end stop contact as well? That would free up some wires too.
Come to think of it, you folks could simplify the builds if you made a custom PCB for the hot end that controlled the fans and lights and accelerometer and perhaps had a PT100 and maybe a separate temperature sensor on it. You could get away with running just 4 wires up to the hot end (Power+, Power-, SDA and SCL). That would make the builds simpler, and save a bunch of money on connectors. It would be more reliable, and easier to build, and you could have bonus features like the temperature sensor could detect overheating / fan failure. With a microcontroller on the hot end, you could do PWMs for the LEDs and have LED visual effects or RGB LEDs.
Posted: Tue May 10, 2016 1:01 pm
by themitch22
Any chance this special calibration with the accelerometer could be implemented in Smoothieware? I know delta's push these ATMega2560's to their limits and it would be a nice future option.
Posted: Tue May 10, 2016 1:30 pm
With patience, I believe that they will come out with this accelerometer calibrator for Repetier first, then the smoothie firmware.
The Reprap software probably doesn't need it but I think it could benefit it also, no more FSRs and that code.
How it will be implemented will be a wait and see game and they have a lot of other responsibilities but slowly and surely we will have
auto calibrating Rostocks...Hallelujah!
Posted: Tue May 10, 2016 1:31 pm
The end stop switches are in the base of the machine and aren't adjustable (or practically, even accessible).
Posted: Tue May 10, 2016 1:42 pm
I did not buy an ERIS because I am in full retirement now which means Social Security only so I have to watch my budget closely but I surely
will jump on the Auto Calibrator for the Rostocks when it comes out. Maybe they will have special pricing tiers so that those retired folks
can get one for less money! (just kidding, that would not be fair to everyone else). I have a lot of spare parts and can build several Kossells
using the 15mmX15mm extrusions when Mitsumi had the $250 sale a few years ago. With all my parts I know I can make 3 Mini Kossels with
only a small outlay for parts I don't have like the Glass and the heatbeds. Looking forward to building these also but I want to wait until I
can save up some extra money. We all have been in the save for funds mode once in a while. Chatter time is over. I know GeneB is
celebrating the fact that I shut up.
Posted: Tue May 10, 2016 2:00 pm
by themitch22
geneb wrote:The end stop switches are in the base of the machine and aren't adjustable (or practically, even accessible).
How does that work? From the videos I saw it homes at the top like it has endstops, unless there's some sort of hall-effect sensor and magnets on the belts, which is an interesting concept.
Posted: Tue May 10, 2016 2:20 pm
by Milamber
Got my shipping notice this morning. Due here on the 12th.
Posted: Tue May 10, 2016 2:45 pm
themitch22 wrote:geneb wrote:The end stop switches are in the base of the machine and aren't adjustable (or practically, even accessible).
What about sensing the load change on the steppers when the arm hits a stop and can no longer move?
Posted: Tue May 10, 2016 2:55 pm
by Milamber
I downloaded Matter Control to get a preview of the software as well as the Eris specific settings listed on the product page. Where do the files in the settings download go?
Posted: Tue May 10, 2016 3:00 pm
U.S. Water Rockets wrote:themitch22 wrote:geneb wrote:The end stop switches are in the base of the machine and aren't adjustable (or practically, even accessible).
The end stops are in the bottom. If I remember right, there's a clip on the belt that hits the switch.
Posted: Wed May 11, 2016 1:58 pm
by Mac The Knife
It Lives!!! I just had to get into the settings and select COM 3, to connect to the printer.
Posted: Wed May 11, 2016 2:41 pm
by johnoly99
Congrats Mac! The first truly wild one is out! How'd the calibration probe work for you? PS, we almost drove it up to you when we went to print the label
Posted: Wed May 11, 2016 3:27 pm
by Mac The Knife
Calibration was painless., I don't know if it was necessary, but I changed the file designation from .txt, to .GCODE so that MatterControl would find it.
Posted: Wed May 11, 2016 3:28 pm
by Mac The Knife
and the packaging looks pretty durable.
Posted: Wed May 11, 2016 3:31 pm
by Mac The Knife
First print was the cube,,,, Second print job is this one from Thingiverse
http://www.thingiverse.com/thing:617395
Posted: Wed May 11, 2016 3:48 pm
by JATMN
Mac, Got any pictures of completed prints?
Posted: Wed May 11, 2016 4:03 pm
by Mac The Knife
JATMN wrote:Mac, Got any pictures of completed prints?
Nah, it's still printing the vase, and I need to tweak the default settings in Matterslice. I think .25 mm layer thickness is a little much to print in vase mode. It isn't a good representation of what the Eris can do.
