I changed the setting the Rostock software the the Z-probe is enable. The test with G31 shows open = L and close = H.
If I run the calibration with Vers. 2.05A or 2.1.1PA the nozzle; crashed in the bed.
I also tested with the pull up resistor and open = H and closed = L but still the same. The software doesn't react on the switch state.
What did I wrong?
Re: OpenDACT(Delta Automatic Calibration Tool) - For Repetie
Posted: Mon Nov 30, 2015 12:38 am
by Micael
At this point it would seem like the z-probe option is not working very well (at least not for 2.05A) http://forum.seemecnc.com/viewtopic.php?p=78704#p78704 there have been quite a lot of reports of it crashing, including me I believe some people had success by significantly increasing z-probe height but not sure.
This assuming the probe doesn't crash right away in all calibration methods, if it does you can try increasing the z-probe height which should solve the problem (assuming it's crashing right away), if it doesn't then there is probably something wrong with your setup (unlikely).
Posted: Mon Nov 30, 2015 4:45 am
by teoman
I searched but could not find an stl to attach a digital micrometer to the endeffector.
If anyone has one would they mind sharing it?
Posted: Mon Nov 30, 2015 6:45 am
by D-G-C
Micael wrote:At this point it would seem like the z-probe option is not working very well (at least not for 2.05A) http://forum.seemecnc.com/viewtopic.php?p=78704#p78704 there have been quite a lot of reports of it crashing, including me I believe some people had success by significantly increasing z-probe height but not sure.
OK. I will try it with a higher Z offset. If itd doesn't work I will try the HTML version.
Posted: Mon Nov 30, 2015 4:03 pm
by RollieRowland
SirLinhart wrote:Our issue sounds similar to mhackney's. Regardless of calibration method we end up with 2 dips in 2 spots in the bed. Belts are evenly tight, skates are well locked in, rubber bands on the arms. We have an adjustable limit switch Z-probe that we set to match the position of the hotend to about .3mm. Have repositioned the bed multiple times, verified level by using a Starrett level. Multiple iterations though opendact from 2.0 to current on all modes. This has consumed a nauseating number of hours. I did pick up a set of tricklaser arms/effector/skates for a mex metal build, I can try them to see if it makes a difference, that will be our next step. If that fails then I'm not sure what to do besides an entire rebuild, and I'm not sure if Caspers frame can handle it.
If I still see failure, would generating a height map be useful to you Rollie? I could generate it with the Z-probe, just need to figure out how to use the G38 command and then determine a point set to check from.
Yes, you are most likely having a similar issue. So if you would like to generate a height map then we could try and diagnose the issue.
Micael wrote:
At this point it would seem like the z-probe option is not working very well (at least not for 2.05A) viewtopic.php?p=78704#p78704 there have been quite a lot of reports of it crashing, including me I believe some people had success by significantly increasing z-probe height but not sure.
Yes, it most likely isn't working. I never fully tested in those versions. I am currently fixing version 3.0s zProbe setting, for now if anyone is using it I recommend manually setting the zheight with the probe down and setting the zheight again afterwards.
What did I wrong?
If the software doesn't react at all when the state is changed then it is most definitely the settings in your firmware.
This is what everything should be set at (on_high may differ).
Posted: Mon Nov 30, 2015 5:25 pm
If you're using FSRs under the bed, I think Z_PROBE_HEIGHT should be 0.
Posted: Mon Nov 30, 2015 5:47 pm
by RollieRowland
geneb wrote:If you're using FSRs under the bed, I think Z_PROBE_HEIGHT should be 0.
Correct, I left the default value for the rmax2. The value in my eeprom is currently set to zero.
Posted: Mon Nov 30, 2015 8:47 pm
by 626Pilot
mhackney wrote:In the meantime, I did pick up one of the Max Metal kits that Eagle sold. I am thinking about building it up, calibrating it so I know it is good and then moving the effectors, arms and carriages from my V1 to this setup to test and vice versa. It should be an interesting test to see where the problem migrates.
If this is the Trick Laser kit, I would advise you to put it together without delay. The MAX METAL is far easier to assemble, and designed to be auto-aligning. MUCH less time to assemble, and a lot fewer ghosts to chase. My firmware's calibration system routinely finds tower radius offsets near zero, which is ideal.
If you want to build more printers and wonder whether to get a Rostock MAX v2 or a MAX METAL, go with the MAX METAL. The price is VERY reasonable, and the time you'll save on assembly and troubleshooting alone, for a guy like you who prints for a living, is MORE than worth it. Frankly, I think SeeMeCNC should sell the MAX METAL as the Rostock MAX 3, fleshed out into a full kit of course.
Posted: Mon Nov 30, 2015 9:41 pm
Yeah, it's a trick laser max metal. It will be the 6th delta in my stable. The Max is a V1 (more in a minute) the others are all kossel derivatives (mini, 250, etc) and they are all nicely calibrated over the full build plate.
Now an update on my V1 - i swapped in the trick laser aluminum effector and the problem went away! That does tell me that the issue was something in the effector. But, folks should not panic - this was an early V1 and the new design is much improved. Also, I've had many different hot ends in different configurations and I do recall an early experiment with an E3D that I tried to eek out every last mm of Z height being too close and heating the effector up. In retrospect, that was probably where the problem introduced (warpage).
I'm building out the max metal with .9° steppers, duet .8.5 (when they are back in stock!) and every other bell and whistle. I'm hoping the Bondtech QR filament drivers are the bees knees. My 2 arrived today but I'm in Rochester NY for the week and can't test them.
Posted: Mon Nov 30, 2015 11:52 pm
by 626Pilot
I built my MAX METAL with 0.9 degree steppers, and my extruders with 5.19:1-geared steppers from tridprinting.com. The 0.9s have less unpowered holding force, so an extruder setup that would stay put with my 1.8-degree Max would fall the moment the power was shut off.
I have a flying triple-extruder platform, and three of those obviously weigh a good deal. I'm using a system of paracord cable tied to the carriages, and to masts at the top of the printer, to take up the weight. I'm debating whether to stay with this, or ditch the mast supports and use some kind of counterweight system to make the carriages functionally weightless. I was clamping my extruders to the arms before, but that didn't always result in a good low-friction filament path.
Posted: Sat Dec 05, 2015 10:00 am
by Paxy
First of all, great job for version 3 of this great tool.
During this writing I am still trying to complete calibration process after heat-bed is changed.
With 3.0.0A calibration process (Basic calibration) took very long as it pause for 2 seconds after every move.
Is there any parameter that can be changed to make calibration faster. With 2.0.5 I had continuous movement during calibration and entire process finishes in about 30 minutes (H.A.I Calib).
Z probe to center, and Z probe to fist (close to the X axe) point is without delay, every other movement with 2 seconds delay.
P.S. Iterative Calibration button do not start any action (unlike 3.0.0PA)
Also there is some issue with Print console that not showing Z height when it is triged but later when this round end. (Perhaps this is reason for 2s delay issue).
Posted: Sat Dec 05, 2015 3:00 pm
by duvdev
Hi
What do mean when you say
"The zprobe setting does not operate properly yet, so it requires that you manually set your z height with your probe in place prior to calibrating "
Do I have to place a paper on the bed and down the head until it grub the paper and the add the probe and see how much it is under the hot end?
Posted: Wed Dec 09, 2015 10:40 pm
by RollieRowland
Paxy wrote:First of all, great job for version 3 of this great tool.
Yes, there is no calculation for travel time at the moment. This is planned however. For the iterative calibration, it is also unfinished.
As for the print console, the arduino itself is only able to have a single processing thread. So when the printer is moving to a position it can not send any values i.e. the delay.
duvdev wrote:
Hi
What I mean here is that the height of the zprobe is not calculated by the program. Therefore the final z height will not be able to be printed on. All parameters except the z max length will be correct though.
Posted: Thu Dec 17, 2015 10:43 am
by kalliator
Hi!
is it possible to implement language support in your tool RollieRowland? I tried to switch my OS to english but it does not work.
for Example: Diagonal Rod lenght is 418.000 and that comes out as 418000. so I have no chance to run that wonderfull tool.
Any Help would be greatly appreciated !
thanks,
Kalle
Posted: Thu Dec 17, 2015 1:28 pm
by Jrjones
kalliator wrote:Hi!
thanks,
Kalle
It's probably your number format settings that you need to change, not your language. I've ran into this before since Europe and other places use a comma ',' as a decimal place, whereas Canada/US use a dot '.'
In Windows it's under Control Panel > Region and Language > Additional Settings > Numbers
Change the "Decimal Symbol" to '.' and the "Digit Grouping Symbol to "," and click apply. You can type them in the field if they aren't in the drop down list.
Posted: Thu Dec 17, 2015 5:54 pm
by kalliator
Jrjones wrote:
kalliator wrote:Hi!
thanks,
Kalle
Thanks a lot! You absolutely made my day .
I guess there are many people who have the same problem as me... and that´s the solution!
Posted: Tue Dec 22, 2015 4:08 pm
by Jrjones
I was trying V3.00A (does V3.00PA come before or after 3.00A? It might be helpful to put a date behind the version names as well,) and it sometimes measures the same point twice, then moves over to above another point, doesn't measure and then moves on to the other points. It then moves the end effector about 100mm above the bed and get stuck in a loop ('wait' keeps scrolling in the message window).
Am I using any of the wrong settings? I just leave them all on the default except for the plate diameter and use the basic calibration.
EDIT: I am now using the version uploaded to Github, which doesn't do the above behavior.
But after about the third calibration iteration, it changes both the horizontal radius and Z-height too much, which causes the hot end to run full speed into the bed. Normally it proceeds at Z-probing speed.
EDIT #2: It now seems to behaving properly. Currently on iteration 22 without it crashing or anything abnormal
Posted: Tue Dec 22, 2015 6:10 pm
by Jrjones
Hmm, this seems to be an exercise in frustration. When the tool does start behaving (see above post), it makes changes that are too drastic, ie a horizontal radius change from 127 to 134, which is way too high.
I'm also not sure why its necessary to change the steps per mm, as I've measured the movement of each axis and used that for my correct steps/mm.
Anyways, if it helps, here is the output from the console and printer console:
Console:
ok 21
EPR:0 1028 0 Language
EPR:2 75 250000 Baudrate
EPR:3 129 101.450 Filament printed [m]
EPR:2 125 54842 Printer active
EPR:2 79 0 Max. inactive time [ms,0=off]
EPR:2 83 360000 Stop stepper after inactivity [ms,0=off]
EPR:3 11 80.0000 Steps per mm
EPR:3 23 300.000 Max. feedrate [mm/s]
EPR:3 35 120.000 Homing feedrate [mm/s]
EPR:3 39 35.000 Max. jerk [mm/s]
EPR:3 133 0.000 X min pos [mm]
EPR:3 137 0.000 Y min pos [mm]
EPR:3 141 0.000 Z min pos [mm]
EPR:3 145 130.000 X max length [mm]
EPR:3 149 130.000 Y max length [mm]
EPR:3 153 650.808 Z max length [mm]
EPR:3 59 1850.000 Acceleration [mm/s^2]
EPR:3 71 3000.000 Travel acceleration [mm/s^2]
EPR:3 881 269.000 Diagonal rod length [mm]
EPR:3 885 129.730 Horizontal rod radius at 0,0 [mm]
EPR:3 925 130.000 Max printable radius [mm]
EPR:1 891 70 Segments/s for travel
EPR:1 889 180 Segments/s for printing
EPR:1 893 153 Tower X endstop offset [steps]
EPR:1 895 240 Tower Y endstop offset [steps]
EPR:1 897 264 Tower Z endstop offset [steps]
EPR:3 901 210.000 Alpha A(210):
EPR:3 905 330.000 Alpha B(330):
EPR:3 909 90.000 Alpha C(90):
EPR:3 913 0.000 Delta Radius A(0):
EPR:3 917 0.000 Delta Radius B(0):
EPR:3 921 0.000 Delta Radius C(0):
EPR:3 933 0.000 Corr. diagonal A [mm]
EPR:3 937 0.000 Corr. diagonal B [mm]
EPR:3 941 0.000 Corr. diagonal C [mm]
EPR:3 1024 0.000 Coating thickness [mm]
EPR:3 808 0.000 Z-probe height [mm]
EPR:3 929 10.000 Max. z-probe - bed dist. [mm]
EPR:3 812 10.000 Z-probe speed [mm/s]
EPR:3 840 100.000 Z-probe x-y-speed [mm/s]
EPR:3 800 0.000 Z-probe offset x [mm]
EPR:3 804 0.000 Z-probe offset y [mm]
EPR:3 816 0.000 Z-probe X1 [mm]
EPR:3 820 100.000 Z-probe Y1 [mm]
EPR:3 824 86.600 Z-probe X2 [mm]
EPR:3 828 -50.000 Z-probe Y2 [mm]
EPR:3 832 -86.600 Z-probe X3 [mm]
EPR:3 836 -50.000 Z-probe Y3 [mm]
EPR:3 1036 0.000 Z-probe bending correction A [mm]
EPR:3 1040 0.000 Z-probe bending correction B [mm]
EPR:3 1044 0.000 Z-probe bending correction C [mm]
EPR:0 880 1 Autolevel active (1/0)
EPR:0 106 3 Bed Heat Manager [0-3]
EPR:0 107 255 Bed PID drive max
EPR:0 124 80 Bed PID drive min
EPR:3 108 30.375 Bed PID P-gain
EPR:3 112 33.000 Bed PID I-gain
EPR:3 116 290.000 Bed PID D-gain
EPR:0 120 255 Bed PID max value [0-255]
EPR:3 200 92.400 Extr.1 steps per mm
EPR:3 204 100.000 Extr.1 max. feedrate [mm/s]
EPR:3 208 20.000 Extr.1 start feedrate [mm/s]
EPR:3 212 6500.000 Extr.1 acceleration [mm/s^2]
EPR:0 216 1 Extr.1 heat manager [0-3]
EPR:0 217 230 Extr.1 PID drive max
EPR:0 245 40 Extr.1 PID drive min
EPR:3 218 31.3600 Extr.1 PID P-gain/dead-time
EPR:3 222 2.1800 Extr.1 PID I-gain
EPR:3 226 112.9000 Extr.1 PID D-gain
EPR:0 230 255 Extr.1 PID max value [0-255]
EPR:2 231 0 Extr.1 X-offset [steps]
EPR:2 235 0 Extr.1 Y-offset [steps]
EPR:2 290 0 Extr.1 Z-offset [steps]
EPR:1 239 1 Extr.1 temp. stabilize time
EPR:1 250 150 Extr.1 temp. for retraction when heating [C]
EPR:1 252 2310 Extr.1 distance to retract when heating [mm]
EPR:0 254 255 Extr.1 extruder cooler speed [0-255]
ok 21
ok 21
Info:Autoleveling disabled
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:650.812 E:0.0000
Info:Autoleveling enabled
wait
ok 21
wait
wait
wait
wait
ok 21
Z-probe:9.93 X:0.28 Y:-0.70 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:9.91 X:-83.12 Y:-48.90 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.99 X:83.68 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.98 X:83.68 Y:-48.90 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:10.11 X:-83.12 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.94 X:0.28 Y:95.70 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:10.00 X:0.28 Y:-97.10 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
Transformation matrix: 1.000000 0.000000 -0.000217 0.000000 1.000000 0.000542 0.000217 -0.000542 1.000000
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:650.737 E:0.0000
ok 21
wait
ok 21
Z-probe:11.85 X:0.28 Y:-0.70 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.88 X:-83.12 Y:-48.90 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.82 X:83.68 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.40 X:83.68 Y:-48.90 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.36 X:-83.12 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.84 X:0.28 Y:95.70 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.93 X:0.28 Y:-97.10 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:652.593 E:0.0000
ok 21
wait
ok 21
Z-probe:10.17 X:0.28 Y:-0.70 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:10.05 X:-83.12 Y:-48.90 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.20 X:83.68 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.87 X:83.68 Y:-48.90 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.04 X:-83.12 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.03 X:0.28 Y:95.70 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.18 X:0.28 Y:-97.10 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:652.764 E:0.0000
ok 21
wait
wait
ok 21
Z-probe:2.19 X:0.28 Y:-0.70 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:3.19 X:-83.12 Y:-48.90 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:3.05 X:83.68 Y:47.49 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:2.92 X:83.68 Y:-48.90 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.01 X:-83.12 Y:47.49 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.11 X:0.28 Y:95.69 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.10 X:0.28 Y:-97.11 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:644.943 E:0.0000
ok 21
wait
ok 21
Z-probe:11.07 X:0.28 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.16 X:-83.12 Y:-48.90 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.42 X:83.68 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.01 X:83.68 Y:-48.90 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.18 X:-83.12 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.12 X:0.28 Y:95.70 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.16 X:0.28 Y:-97.10 zCorr:0.00
ok 21
ok 21
ok 21
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:646.021 E:0.0000
ok 21
wait
ok 21
Z-probe:2.57 X:0.28 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:3.30 X:-83.12 Y:-48.90 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:3.19 X:83.68 Y:47.50 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.04 X:83.68 Y:-48.90 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.46 X:-83.12 Y:47.50 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.24 X:0.28 Y:95.70 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.34 X:0.28 Y:-97.10 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:638.594 E:0.0000
ok 21
wait
ok 21
Z-probe:3.15 X:0.27 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:4.47 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:4.32 X:83.68 Y:47.51 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:4.31 X:83.68 Y:-48.89 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:4.28 X:-83.12 Y:47.51 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:4.37 X:0.27 Y:95.70 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:4.51 X:0.27 Y:-97.09 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:631.735 E:0.0000
ok 21
wait
ok 21
Z-probe:10.91 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.35 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.37 X:83.68 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.91 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.94 X:-83.12 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.06 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.86 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:632.642 E:0.0000
ok 21
wait
ok 21
Z-probe:12.24 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:12.17 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.16 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.96 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.26 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.21 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.09 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:634.894 E:0.0000
ok 21
wait
ok 21
Z-probe:7.22 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:7.64 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.65 X:83.67 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.43 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.57 X:-83.13 Y:47.51 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.54 X:0.27 Y:95.71 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.60 X:0.27 Y:-97.09 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:632.109 E:0.0000
ok 21
wait
ok 21
Z-probe:6.82 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:7.33 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.44 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.11 X:83.67 Y:-48.89 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.48 X:-83.13 Y:47.52 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.18 X:0.27 Y:95.71 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.20 X:0.27 Y:-97.08 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:628.927 E:0.0000
ok 21
wait
ok 21
Z-probe:2.18 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:3.37 X:-83.13 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:2.96 X:83.67 Y:47.52 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.19 X:83.67 Y:-48.88 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.07 X:-83.13 Y:47.52 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.19 X:0.27 Y:95.72 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.39 X:0.27 Y:-97.09 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:621.114 E:0.0000
ok 21
wait
ok 21
Z-probe:15.66 X:0.27 Y:-0.67 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:15.21 X:-83.13 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.85 X:83.67 Y:47.53 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.81 X:83.67 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.85 X:-83.13 Y:47.53 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.92 X:0.27 Y:95.73 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.85 X:0.27 Y:-97.07 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:626.770 E:0.0000
ok 21
ok 21
Z-probe:15.45 X:0.27 Y:-0.67 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:15.16 X:-83.13 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:15.03 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.96 X:83.67 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:15.08 X:-83.13 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:15.04 X:0.27 Y:95.72 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:15.08 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:632.217 E:0.0000
ok 21
ok 21
Z-probe:9.83 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:9.50 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.41 X:83.68 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.37 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.37 X:-83.12 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.45 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.44 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:632.054 E:0.0000
ok 21
wait
ok 21
Z-probe:11.27 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.33 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.12 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.21 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.50 X:-83.13 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.26 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.27 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:633.319 E:0.0000
ok 21
wait
ok 21
Z-probe:8.70 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:8.85 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.65 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.70 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.59 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.74 X:0.27 Y:95.71 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:8.76 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:632.017 E:0.0000
ok 21
wait
ok 21
Z-probe:14.45 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:14.14 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.08 X:83.67 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.03 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.02 X:-83.13 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.11 X:0.27 Y:95.72 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.08 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:636.471 E:0.0000
ok 21
ok 21
Z-probe:11.61 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.37 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.53 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.22 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.31 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.34 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.29 X:0.27 Y:-97.09 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:638.079 E:0.0000
ok 21
wait
ok 21
Z-probe:6.82 X:0.27 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:7.14 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:6.91 X:83.67 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:6.96 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.20 X:-83.13 Y:47.51 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.03 X:0.27 Y:95.70 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.26 X:0.27 Y:-97.09 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:634.898 E:0.0000
ok 21
wait
ok 21
Z-probe:6.19 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:6.76 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:6.67 X:83.67 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:6.61 X:83.67 Y:-48.89 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:6.68 X:-83.12 Y:47.51 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:6.72 X:0.27 Y:95.71 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:6.59 X:0.27 Y:-97.09 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:631.083 E:0.0000
ok 21
wait
ok 21
Z-probe:12.40 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:12.30 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.24 X:83.68 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.23 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.17 X:-83.12 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.25 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.28 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:633.482 E:0.0000
ok 21
wait
ok 21
Z-probe:11.46 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.29 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.22 X:83.67 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.20 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.19 X:-83.13 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.27 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.22 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:634.947 E:0.0000
ok 21
wait
ok 21
Z-probe:12.14 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.85 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.77 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.70 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.97 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.87 X:0.27 Y:95.72 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.73 X:0.27 Y:-97.09 zCorr:0.00
ok 21
ok 21
ok 21
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:637.085 E:0.0000
ok 21
wait
ok 21
Z-probe:9.47 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:9.19 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.20 X:83.67 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.09 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.48 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.20 X:0.27 Y:95.72 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:9.26 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:636.554 E:0.0000
ok 21
wait
ok 21
Z-probe:2.34 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:3.45 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:3.48 X:83.68 Y:47.51 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.36 X:83.68 Y:-48.89 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.16 X:-83.12 Y:47.51 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.41 X:0.27 Y:95.71 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:3.43 X:0.27 Y:-97.09 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:628.902 E:0.0000
ok 21
wait
ok 21
Z-probe:12.48 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:12.62 X:-83.12 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:13.14 X:83.68 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.37 X:83.68 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.32 X:-83.12 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.87 X:0.27 Y:95.72 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.43 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:631.380 E:0.0000
ok 21
wait
ok 21
Z-probe:9.42 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:9.54 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.33 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.59 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.90 X:-83.13 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.47 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.57 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:630.794 E:0.0000
ok 21
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.30 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.15 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.08 X:83.67 Y:-48.89 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.25 X:-83.13 Y:47.52 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.39 X:0.27 Y:95.72 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.27 X:0.27 Y:-97.08 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:627.615 E:0.0000
ok 21
wait
ok 21
Z-probe:11.62 X:0.27 Y:-0.67 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.57 X:-83.13 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.55 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.38 X:83.67 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.34 X:-83.13 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.47 X:0.27 Y:95.72 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.56 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:629.243 E:0.0000
ok 21
wait
ok 21
Z-probe:9.53 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:9.63 X:-83.13 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.36 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.44 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.60 X:-83.13 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.55 X:0.27 Y:95.72 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.54 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:628.770 E:0.0000
ok 21
wait
ok 21
Z-probe:11.90 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.77 X:-83.12 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.64 X:83.68 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.58 X:83.68 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.60 X:-83.12 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.70 X:0.27 Y:95.72 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.69 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:630.669 E:0.0000
ok 21
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:11.68 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.68 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.52 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.58 X:-83.13 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.62 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.57 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:632.571 E:0.0000
ok 21
wait
ok 21
Z-probe:10.08 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:9.81 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.96 X:83.68 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.67 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.74 X:-83.12 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.71 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.80 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:632.645 E:0.0000
ok 21
wait
ok 21
Z-probe:5.36 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:5.66 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:5.41 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:5.46 X:83.67 Y:-48.89 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:5.54 X:-83.13 Y:47.52 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:5.70 X:0.27 Y:95.71 zCorr:0.00
wait
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:5.61 X:0.27 Y:-97.09 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:628.007 E:0.0000
ok 21
wait
ok 21
Z-probe:13.63 X:0.27 Y:-0.67 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:13.80 X:-83.13 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:13.57 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:13.55 X:83.67 Y:-48.88 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:13.77 X:-83.13 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:13.71 X:0.27 Y:95.72 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:13.68 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:631.638 E:0.0000
ok 21
ok 21
Z-probe:10.73 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:10.66 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.54 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.51 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.63 X:-83.13 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.64 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.54 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:632.371 E:0.0000
ok 21
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:11.35 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.42 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.29 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.23 X:-83.13 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.31 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.31 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:633.827 E:0.0000
ok 21
wait
ok 21
Z-probe:9.76 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:9.90 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.00 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.72 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.83 X:-83.13 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.85 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.83 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:633.590 E:0.0000
ok 21
wait
ok 21
Z-probe:7.16 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:7.46 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.16 X:83.68 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.26 X:83.68 Y:-48.89 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.40 X:-83.12 Y:47.52 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.32 X:0.27 Y:95.71 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.40 X:0.27 Y:-97.08 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:630.753 E:0.0000
ok 21
wait
ok 21
Z-probe:11.12 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.27 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.14 X:83.68 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.10 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.12 X:-83.12 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.18 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.21 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:631.871 E:0.0000
ok 21
wait
ok 21
Z-probe:11.33 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.27 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.19 X:83.67 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.07 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.08 X:-83.13 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
ok 21
ok 21
ok 21
ok 21
Z-probe:11.12 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:633.192 E:0.0000
ok 21
wait
ok 21
Z-probe:12.06 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.83 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.73 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.74 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.95 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.81 X:0.27 Y:95.72 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.78 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:635.262 E:0.0000
ok 21
wait
ok 21
Z-probe:8.73 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:8.83 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.71 X:83.67 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.67 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.85 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.75 X:0.27 Y:95.71 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:8.77 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:633.990 E:0.0000
ok 21
wait
ok 21
Z-probe:8.97 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:8.98 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.94 X:83.67 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.80 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.93 X:-83.13 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.09 X:0.27 Y:95.71 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:8.87 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:632.959 E:0.0000
ok 21
wait
ok 21
Z-probe:11.98 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.82 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.88 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.67 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.77 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.78 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.82 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:634.938 E:0.0000
ok 21
wait
ok 21
Z-probe:6.74 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:7.19 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.14 X:83.67 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.02 X:83.67 Y:-48.89 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.02 X:-83.13 Y:47.51 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.11 X:0.27 Y:95.71 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.11 X:0.27 Y:-97.09 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:631.675 E:0.0000
ok 21
wait
ok 21
Z-probe:10.84 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:10.90 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.90 X:83.68 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.74 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.71 X:-83.12 Y:47.52 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.95 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.83 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:632.521 E:0.0000
ok 21
wait
ok 21
Z-probe:12.30 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:12.16 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.02 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
ok 21
ok 21
ok 21
ok 21
Z-probe:12.06 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.22 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.13 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:634.823 E:0.0000
ok 21
wait
ok 21
Z-probe:12.17 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.80 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.75 X:83.67 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.66 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.83 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.80 X:0.27 Y:95.72 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.81 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:636.983 E:0.0000
ok 21
wait
ok 21
Z-probe:8.07 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:8.09 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.93 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.90 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.13 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.16 X:0.27 Y:95.70 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.98 X:0.27 Y:-97.09 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:635.052 E:0.0000
ok 21
wait
ok 21
Z-probe:11.48 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.58 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.69 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.44 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.48 X:-83.13 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
ok 21
ok 21
ok 21
ok 21
Z-probe:11.50 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:636.536 E:0.0000
ok 21
wait
ok 21
Z-probe:10.83 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:10.78 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.67 X:83.67 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.63 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.68 X:-83.13 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.68 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.77 X:0.27 Y:-97.10 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
Transformation matrix: 1.000000 0.000000 -0.000217 0.000000 1.000000 0.000542 0.000217 -0.000542 1.000000
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
Info:Autoleveling disabled
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:637.373 E:0.0000
Info:Autoleveling enabled
ok 21
wait
ok 21
Z-probe:9.48 X:0.27 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:9.58 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.55 X:83.67 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.43 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.50 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.50 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.59 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:636.849 E:0.0000
ok 21
wait
ok 21
Z-probe:7.93 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:8.23 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.09 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.09 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.23 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.17 X:0.27 Y:95.70 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:8.11 X:0.27 Y:-97.09 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:634.778 E:0.0000
ok 21
wait
ok 21
Z-probe:10.92 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:11.02 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.00 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.19 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.96 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:11.01 X:0.27 Y:95.72 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:10.93 X:0.27 Y:-97.08 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:635.692 E:0.0000
ok 21
wait
ok 21
Z-probe:15.34 X:0.27 Y:-0.68 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:14.73 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.67 X:83.68 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.60 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.66 X:-83.12 Y:47.51 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.65 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:14.70 X:0.27 Y:-97.09 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:641.043 E:0.0000
ok 21
ok 21
Z-probe:9.20 X:0.28 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:9.28 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.06 X:83.67 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.98 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.06 X:-83.12 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.16 X:0.28 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.10 X:0.28 Y:-97.10 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:640.238 E:0.0000
ok 21
wait
ok 21
Z-probe:13.48 X:0.28 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:12.92 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.86 X:83.68 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.77 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.97 X:-83.13 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.83 X:0.28 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.86 X:0.28 Y:-97.09 zCorr:0.00
ok 21
ok 21
ok 21
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:643.715 E:0.0000
ok 21
wait
ok 21
Z-probe:7.02 X:0.28 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:7.28 X:-83.12 Y:-48.90 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.22 X:83.68 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:7.15 X:83.68 Y:-48.90 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.20 X:-83.12 Y:47.50 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.25 X:0.28 Y:95.70 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:7.33 X:0.28 Y:-97.10 zCorr:0.00
wait
ok 21
ok 21
ok 21
wait
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:640.738 E:0.0000
ok 21
wait
ok 21
Z-probe:8.82 X:0.28 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:9.22 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.16 X:83.68 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.24 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.07 X:-83.12 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:9.07 X:0.28 Y:95.71 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:9.11 X:0.28 Y:-97.10 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:639.560 E:0.0000
ok 21
wait
ok 21
Z-probe:13.15 X:0.27 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:12.89 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.86 X:83.67 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.74 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.84 X:-83.12 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.80 X:0.27 Y:95.71 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:12.83 X:0.27 Y:-97.09 zCorr:0.00
ok 21
ok 21
ok 21
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:642.703 E:0.0000
ok 21
wait
ok 21
Z-probe:8.31 X:0.28 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:8.48 X:-83.12 Y:-48.90 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.42 X:83.68 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.50 X:83.68 Y:-48.90 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.62 X:-83.12 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.39 X:0.28 Y:95.71 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:8.45 X:0.28 Y:-97.10 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:641.023 E:0.0000
ok 21
wait
ok 21
Z-probe:8.07 X:0.28 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:8.75 X:-83.12 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.40 X:83.67 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.59 X:83.67 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.29 X:-83.12 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:8.32 X:0.28 Y:95.71 zCorr:0.00
wait
ok 21
ok 21
ok 21
ok 21
Z-probe:8.30 X:0.28 Y:-97.10 zCorr:0.00
ok 21
ok 21
ok 21
wait
wait
wait
wait
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
SelectExtruder:0
FlowMultiply:100
ok 21
ok 21
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:639.089 E:0.0000
ok 21
wait
ok 21
Z-probe:20.98 X:0.27 Y:-0.69 zCorr:0.00
ok 21
ok 21
ok 21
Z-probe:19.79 X:-83.13 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:19.92 X:83.68 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:20.02 X:83.68 Y:-48.89 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
Z-probe:19.90 X:-83.13 Y:47.50 zCorr:0.00
ok 21
ok 21
ok 21
ok 21
ok 21
Z-probe:19.87 X:0.27 Y:-97.09 zCorr:0.00
ok 21
ok 21
ok 21
wait
Re: OpenDACT(Delta Automatic Calibration Tool) - For Repetie
Posted: Wed Dec 23, 2015 7:47 pm
by Micael
Did you use the basic mode, because RollieRowland said on the last page that it was the only mode that was currently working (not sure if still true).
If you did I would advise making a mattercontrol macro to check for repeatability, I had that problem and went through several FSR systems and replaced arms and so on until I discovered that it was actually the e3d mount that was causing those issues.
Posted: Wed Dec 23, 2015 9:06 pm
by Jrjones
Micael wrote:Did you use the basic mode, because RollieRowland said on the last page that it was the only mode that was currently working (not sure if still true).
Yes, I used basic mode, as well as set the max iterations to 10, which apparently doesn't work.
What do you mean by repeatability of the e3d mount?
I'm currently devising a mount for an inductive probe, I was using a switch which did have some play in when it triggered.
Posted: Wed Dec 23, 2015 9:23 pm
by timmyg247
I used the Delta-Bed-Calibration-Tool with a dial which seemed to work. I calibrated Z height than set the new height and every print i try the printer head is 10mm over the bed. Im at a lose. Im at that point where i'm imagining how good it would feel to throw this out of the window. I don't want to feel this way. Any help would be great.
Posted: Wed Dec 23, 2015 9:47 pm
by Micael
In my very specific case it was the piece that made sure the e3d v6 in place that had some play, the problem was especially big when I didn't had the cables secured, but by repeatability I mean any problem that can affect repeat readings, you should do a macro that imitates the movements of the software, and note down the values you get and see if they are consistent, ideally they should always be exactly the same value because if the values differ significantly it will be hard for the software to know what to do.
I believe this was the macro code I used to try my repeatability:
G28
G1 Z10 X0 Y0 F5000
G30
G1 Z10 X-110 Y-65 F5000
G30
G1 Z10 X0 Y0 F5000
G1 Z10 X110 Y65 F5000
G30
G1 Z10 X0 Y0 F5000
G1 Z10 X110 Y-65 F5000
G30
G1 Z10 X0 Y0 F5000
G1 Z10 X-110 Y65 F5000
G30
G1 Z10 X0 Y0 F5000
G1 Z10 X0 Y130 F5000
G30
G1 Z10 X0 Y0 F5000
G1 Z10 X0 Y-130 F5000
G30
Can't say with certainty since I don't have my printer connected to the computer at the moment, but either way the gist of it is that you want to emulate the movements the software is doing, and probe more or less in the same place the software is doing, and repeat that a couple of times while nothing down the values to see what's the difference between different readings on the same point, so for example:
Say reading 1 you get on X tower a 10.02 measurement, and at reading 2 you get a reading of 9.98 at the X tower, and reading 3 you get something like 10.03, that would mean that you have a margin of error on the tower X readings of around 0.05mm which is ofc not good enough to get a 0.025mm calibration accuracy
Posted: Thu Dec 24, 2015 2:23 am
by Jrjones
Yeah I think that was my problem, the switch I was using before had too much variance in it.
I switched to an inductive probe that has a repeatability of +/- 0.035 mm or less (SICK says its <= 2%), so I set the calculation accuracy to +/- 0.04 mm.
After 62 iterations it completed!
Double checked with Repetier's bed height tool, standard deviation of 0.06mm across a 9x9 grid, difference between the maximum and minimum measurement is 0.26mm:
wait
wait
wait
wait
wait
ok 530
EPR:0 1028 0 Language
EPR:2 75 250000 Baudrate
EPR:3 129 106.665 Filament printed [m]
EPR:2 125 57921 Printer active
EPR:2 79 0 Max. inactive time [ms,0=off]
EPR:2 83 360000 Stop stepper after inactivity [ms,0=off]
EPR:3 11 80.0000 Steps per mm
EPR:3 23 300.000 Max. feedrate [mm/s]
EPR:3 35 120.000 Homing feedrate [mm/s]
EPR:3 39 35.000 Max. jerk [mm/s]
EPR:3 133 0.000 X min pos [mm]
EPR:3 137 0.000 Y min pos [mm]
EPR:3 141 0.000 Z min pos [mm]
EPR:3 145 130.000 X max length [mm]
EPR:3 149 130.000 Y max length [mm]
EPR:3 153 558.058 Z max length [mm]
EPR:3 59 1850.000 Acceleration [mm/s^2]
EPR:3 71 3000.000 Travel acceleration [mm/s^2]
EPR:3 881 269.000 Diagonal rod length [mm]
EPR:3 885 129.730 Horizontal rod radius at 0,0 [mm]
EPR:3 925 130.000 Max printable radius [mm]
EPR:1 891 70 Segments/s for travel
EPR:1 889 180 Segments/s for printing
EPR:1 893 63 Tower X endstop offset [steps]
EPR:1 895 123 Tower Y endstop offset [steps]
EPR:1 897 174 Tower Z endstop offset [steps]
EPR:3 901 210.000 Alpha A(210):
EPR:3 905 330.000 Alpha B(330):
EPR:3 909 90.000 Alpha C(90):
EPR:3 913 0.000 Delta Radius A(0):
EPR:3 917 0.000 Delta Radius B(0):
EPR:3 921 0.000 Delta Radius C(0):
EPR:3 933 0.000 Corr. diagonal A [mm]
EPR:3 937 0.000 Corr. diagonal B [mm]
EPR:3 941 0.000 Corr. diagonal C [mm]
EPR:3 1024 0.000 Coating thickness [mm]
EPR:3 808 0.000 Z-probe height [mm]
EPR:3 929 10.000 Max. z-probe - bed dist. [mm]
EPR:3 812 10.000 Z-probe speed [mm/s]
EPR:3 840 100.000 Z-probe x-y-speed [mm/s]
EPR:3 800 0.000 Z-probe offset x [mm]
EPR:3 804 0.000 Z-probe offset y [mm]
EPR:3 816 0.000 Z-probe X1 [mm]
EPR:3 820 100.000 Z-probe Y1 [mm]
EPR:3 824 86.600 Z-probe X2 [mm]
EPR:3 828 -50.000 Z-probe Y2 [mm]
EPR:3 832 -86.600 Z-probe X3 [mm]
EPR:3 836 -50.000 Z-probe Y3 [mm]
EPR:3 1036 0.000 Z-probe bending correction A [mm]
EPR:3 1040 0.000 Z-probe bending correction B [mm]
EPR:3 1044 0.000 Z-probe bending correction C [mm]
EPR:0 880 0 Autolevel active (1/0)
EPR:0 106 3 Bed Heat Manager [0-3]
EPR:0 107 255 Bed PID drive max
EPR:0 124 80 Bed PID drive min
EPR:3 108 30.375 Bed PID P-gain
EPR:3 112 33.000 Bed PID I-gain
EPR:3 116 290.000 Bed PID D-gain
EPR:0 120 255 Bed PID max value [0-255]
EPR:3 200 92.400 Extr.1 steps per mm
EPR:3 204 100.000 Extr.1 max. feedrate [mm/s]
EPR:3 208 20.000 Extr.1 start feedrate [mm/s]
EPR:3 212 6500.000 Extr.1 acceleration [mm/s^2]
EPR:0 216 1 Extr.1 heat manager [0-3]
EPR:0 217 230 Extr.1 PID drive max
EPR:0 245 40 Extr.1 PID drive min
EPR:3 218 31.3600 Extr.1 PID P-gain/dead-time
EPR:3 222 2.1800 Extr.1 PID I-gain
EPR:3 226 112.9000 Extr.1 PID D-gain
EPR:0 230 255 Extr.1 PID max value [0-255]
EPR:2 231 0 Extr.1 X-offset [steps]
EPR:2 235 0 Extr.1 Y-offset [steps]
EPR:2 290 0 Extr.1 Z-offset [steps]
EPR:1 239 1 Extr.1 temp. stabilize time
EPR:1 250 150 Extr.1 temp. for retraction when heating [C]
EPR:1 252 2310 Extr.1 distance to retract when heating [mm]
EPR:0 254 255 Extr.1 extruder cooler speed [0-255]
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:558.062 E:0.0000
wait
ok 530
wait
wait
wait
wait
ok 530
Z-probe:10.05 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.82 X:-108.43 Y:-62.66 zCorr:0.00
ok 530
ok 530
wait
ok 530
ok 530
Z-probe:10.28 X:108.43 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.25 X:108.43 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.11 X:-108.43 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.78 X:0.00 Y:125.33 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.11 X:0.00 Y:-125.33 zCorr:0.00
ok 530
ok 530
ok 530
wait
ok 530
Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:558.112 E:0.0000
ok 530
ok 530
Z-probe:11.44 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.63 X:-108.43 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:12.26 X:108.43 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:11.85 X:108.43 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:11.70 X:-108.43 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:12.07 X:0.00 Y:125.33 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:11.29 X:0.00 Y:-125.33 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:559.550 E:0.0000
ok 530
ok 530
Z-probe:10.03 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.15 X:-108.43 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.74 X:108.43 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.34 X:108.43 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.16 X:-108.43 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.53 X:0.00 Y:125.33 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.78 X:0.00 Y:-125.33 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:559.575 E:0.0000
ok 530
ok 530
Z-probe:9.99 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.14 X:-108.43 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.32 X:108.43 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.54 X:0.00 Y:125.33 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.75 X:0.00 Y:-125.33 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:559.562 E:0.0000
ok 530
ok 530
Z-probe:9.05 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.13 X:-108.43 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.15 X:108.43 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.03 X:108.43 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.43 X:-108.43 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:8.96 X:0.00 Y:125.33 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.20 X:0.00 Y:-125.33 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:558.623 E:0.0000
ok 530
ok 530
Z-probe:0.68 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:2.52 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:2.42 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:2.61 X:108.42 Y:-62.66 zCorr:0.00
wait
ok 530
ok 530
ok 530
ok 530
Z-probe:2.06 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:2.09 X:0.00 Y:125.32 zCorr:0.00
wait
wait
ok 530
ok 530
ok 530
ok 530
Z-probe:2.29 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.298 E:0.0000
ok 530
ok 530
Z-probe:16.08 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:14.94 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:14.86 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:14.88 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:15.18 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:14.79 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:14.96 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:555.376 E:0.0000
ok 530
ok 530
Z-probe:4.48 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:5.66 X:-108.42 Y:-62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:5.55 X:108.42 Y:62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:5.64 X:108.42 Y:-62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:5.58 X:-108.42 Y:62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:5.50 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:5.56 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.860 E:0.0000
ok 530
ok 530
Z-probe:11.50 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:11.20 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:11.21 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:11.22 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:11.22 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:11.12 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:11.21 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:551.355 E:0.0000
ok 530
ok 530
Z-probe:8.61 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:8.90 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:8.88 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:8.89 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:8.85 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:8.79 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:8.85 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.964 E:0.0000
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.05 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.00 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.05 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.99 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.96 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.02 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.961 E:0.0000
ok 530
ok 530
Z-probe:10.74 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.64 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.58 X:108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.58 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.57 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.50 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.58 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.696 E:0.0000
ok 530
ok 530
Z-probe:9.85 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.96 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.87 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.90 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.90 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.82 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.87 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.542 E:0.0000
ok 530
ok 530
Z-probe:10.57 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.51 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.46 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.47 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.45 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.38 X:0.00 Y:125.33 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.46 X:0.00 Y:-125.33 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:551.117 E:0.0000
ok 530
ok 530
Z-probe:9.84 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.95 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.89 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.92 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:9.81 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.89 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.957 E:0.0000
ok 530
ok 530
Z-probe:10.00 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.04 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.00 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.98 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.88 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.98 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.963 E:0.0000
ok 530
ok 530
Z-probe:9.39 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.59 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.54 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.61 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.56 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.49 X:0.00 Y:125.31 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.56 X:0.00 Y:-125.31 zCorr:0.00
ok 530
ok 530
ok 530
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.348 E:0.0000
ok 530
ok 530
Z-probe:10.41 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.33 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.32 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.36 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.33 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.24 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.33 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.757 E:0.0000
ok 530
ok 530
Z-probe:9.36 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.47 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.43 X:108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.48 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.43 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.38 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.42 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.114 E:0.0000
ok 530
ok 530
Z-probe:10.70 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.58 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.57 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.59 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.58 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.49 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.821 E:0.0000
ok 530
ok 530
Z-probe:9.02 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.24 X:-108.42 Y:-62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.22 X:108.42 Y:62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.27 X:108.42 Y:-62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.21 X:-108.42 Y:62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.17 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.21 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.842 E:0.0000
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.47 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.45 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.50 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.46 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.39 X:0.00 Y:125.31 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.47 X:0.00 Y:-125.31 zCorr:0.00
ok 530
ok 530
ok 530
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.412 E:0.0000
ok 530
ok 530
Z-probe:9.70 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.80 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.77 X:108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.82 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.77 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.70 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.75 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.105 E:0.0000
ok 530
ok 530
Z-probe:10.43 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.34 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.34 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.37 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.27 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.34 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.535 E:0.0000
ok 530
ok 530
Z-probe:9.59 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.70 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.66 X:108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.72 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.68 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.62 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.67 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.129 E:0.0000
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.35 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.35 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.539 E:0.0000
ok 530
ok 530
Z-probe:9.74 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.83 X:-108.42 Y:-62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.78 X:108.42 Y:62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.83 X:108.42 Y:-62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.78 X:-108.42 Y:62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.72 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.79 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.282 E:0.0000
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.34 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.33 X:108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.37 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.33 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.36 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.694 E:0.0000
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:9.25 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.22 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.24 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.22 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.18 X:0.00 Y:125.31 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.19 X:0.00 Y:-125.31 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.702 E:0.0000
ok 530
ok 530
Z-probe:10.56 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.47 X:-108.42 Y:-62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.43 X:108.42 Y:62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.47 X:108.42 Y:-62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.43 X:-108.42 Y:62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.38 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.46 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.269 E:0.0000
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.04 X:-108.42 Y:-62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.03 X:108.42 Y:62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.05 X:108.42 Y:-62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.00 X:-108.42 Y:62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.97 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.00 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.257 E:0.0000
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.39 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.36 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.685 E:0.0000
ok 530
ok 530
Z-probe:10.29 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.27 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.23 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.24 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.24 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.16 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.24 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.975 E:0.0000
ok 530
ok 530
Z-probe:9.44 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.62 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.55 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.59 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.54 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:9.55 X:0.00 Y:-125.31 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.423 E:0.0000
ok 530
ok 530
Z-probe:10.84 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.74 X:-108.43 Y:-62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.67 X:108.43 Y:62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.67 X:108.43 Y:-62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.70 X:-108.43 Y:62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.59 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.66 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:551.260 E:0.0000
ok 530
ok 530
Z-probe:9.56 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.67 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.67 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.68 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.66 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.59 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.814 E:0.0000
ok 530
ok 530
Z-probe:9.17 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.36 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.30 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.36 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.31 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.27 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.32 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.990 E:0.0000
ok 530
ok 530
Z-probe:10.85 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.69 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.69 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.69 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.70 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.68 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.832 E:0.0000
ok 530
ok 530
Z-probe:8.60 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:8.91 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:8.87 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:8.91 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:8.86 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:8.84 X:0.00 Y:125.33 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:8.86 X:0.00 Y:-125.33 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
wait
wait
wait
wait
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.435 E:0.0000
ok 530
ok 530
Z-probe:10.97 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.79 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.77 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.81 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.78 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.71 X:0.00 Y:125.31 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.79 X:0.00 Y:-125.31 zCorr:0.00
ok 530
ok 530
ok 530
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.407 E:0.0000
ok 530
ok 530
Z-probe:9.58 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.71 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:9.70 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.65 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
wait
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.994 E:0.0000
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.45 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.46 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.40 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.44 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.551 E:0.0000
ok 530
wait
ok 530
Z-probe:9.31 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.49 X:-108.42 Y:-62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.43 X:108.42 Y:62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.48 X:108.42 Y:-62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.44 X:-108.42 Y:62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.40 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.44 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.863 E:0.0000
ok 530
wait
ok 530
ok 530
ok 530
ok 530
Z-probe:10.69 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.68 X:108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.70 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.69 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.61 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.703 E:0.0000
ok 530
wait
ok 530
Z-probe:9.30 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.47 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.44 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.48 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.43 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.41 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.998 E:0.0000
ok 530
wait
ok 530
Z-probe:10.71 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.57 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.58 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.52 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.57 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.711 E:0.0000
ok 530
wait
ok 530
Z-probe:9.15 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.36 X:-108.42 Y:-62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.32 X:108.42 Y:62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.33 X:108.42 Y:-62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.32 X:-108.42 Y:62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.29 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
wait
wait
wait
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.858 E:0.0000
ok 530
ok 530
Z-probe:10.27 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.22 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.21 X:108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.25 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.22 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.17 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.21 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
Z-probe:10.02 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.04 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.02 X:108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.05 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.02 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.98 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.01 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.150 E:0.0000
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.24 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.25 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.21 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.18 X:0.00 Y:125.31 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.24 X:0.00 Y:-125.31 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.441 E:0.0000
ok 530
ok 530
Z-probe:9.86 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.90 X:-108.42 Y:-62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.88 X:108.42 Y:62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.90 X:108.42 Y:-62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.89 X:-108.42 Y:62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.84 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.88 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.301 E:0.0000
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:9.90 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.88 X:108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.91 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.88 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.85 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.137 E:0.0000
ok 530
wait
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.429 E:0.0000
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:9.89 X:108.42 Y:62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.92 X:108.42 Y:-62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.90 X:-108.42 Y:62.67 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.86 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
wait
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.285 E:0.0000
ok 530
wait
ok 530
Z-probe:10.14 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.13 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.10 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.13 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.12 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.07 X:0.00 Y:125.31 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.10 X:0.00 Y:-125.31 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.425 E:0.0000
ok 530
ok 530
Z-probe:10.12 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.11 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.12 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.12 X:108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.11 X:-108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.06 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.11 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
Z-probe:9.32 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.47 X:-108.42 Y:-62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:9.47 X:108.42 Y:-62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.43 X:-108.42 Y:62.65 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.42 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
wait
ok 530
Z-probe:10.82 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:10.68 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.68 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.63 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.69 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
wait
ok 530
Z-probe:9.05 X:0.00 Y:0.00 zCorr:0.00
ok 530
ok 530
ok 530
Z-probe:9.24 X:-108.42 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.23 X:108.42 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:9.21 X:0.00 Y:125.31 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.21 X:0.00 Y:-125.31 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
wait
wait
wait
wait
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.735 E:0.0000
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.33 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.32 X:108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.33 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.32 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.30 X:0.00 Y:125.32 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.32 X:0.00 Y:-125.32 zCorr:0.00
ok 530
ok 530
ok 530
wait
wait
wait
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:550.153 E:0.0000
ok 530
wait
ok 530
ok 530
ok 530
ok 530
Z-probe:10.02 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.00 X:108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.02 X:108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:9.99 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
wait
wait
wait
wait
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.01 X:-108.41 Y:-62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
Z-probe:10.01 X:108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
Z-probe:10.01 X:-108.41 Y:62.66 zCorr:0.00
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
ok 530
wait
wait
wait
wait
wait
wait
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
ok 530
SelectExtruder:0
FlowMultiply:100
X:0.00 Y:0.00 Z:549.895 E:0.0000
wait
Re: OpenDACT(Delta Automatic Calibration Tool) - For Repetie
Posted: Fri Dec 25, 2015 9:01 am
by SirLinhart
I now have the tricklaser metal effector, arms, skates installed. Now I have some new problems. For one the Z-probe will sometimes "give up" on taking a reading at a random point. It will get about 2/3's down into the bed before going up and continuing on, which gives us a really messed up reading in opendact if we let it finish (once it was like +64), no idea what that's about. Other issue is that the Z-probe results have been way more inconsistent than before, which I think is weird. We swapped out the limit switch we were using because it had too much side travel, this helped but we are about +-.04 right now on accuracy.
Need to find a really quality limit switch that has the little roller. One that has bearings for the roller and is made for precision.
