Page 4 of 5
Re: Foshon's Big and Tall
Posted: Sat May 11, 2013 10:44 pm
by foshon
Poly, glad your here! Does a stripped (stripping) gearbox explain the issues I was having with this?
Posted: Sun May 12, 2013 12:03 am
by cambo3d
did you have all the bearings supporting the drive gear, I think there is 3 in extruder mount that support the drive gear. ultibots guy that sells these said if they aren't supported properly they tend to strip.
he says he uses these with no issues in his printers but i'll see for myself..
Posted: Sun May 12, 2013 5:02 am
cambo3d wrote:did you have all the bearings supporting the drive gear, I think there is 3 in extruder mount that support the drive gear. ultibots guy that sells these said if they aren't supported properly they tend to strip.
Please check that those gears are packed in white grease. The ones I have seen were not greased very well.
Posted: Sun May 12, 2013 10:21 am
by foshon
Yes, I used all three, there are two that set behind the drive gear and one in the idler assembly.
Posted: Sun May 12, 2013 10:22 am
by foshon
Will do, thank you.
Posted: Sun May 12, 2013 3:58 pm
by foshon
Posted: Sat May 18, 2013 10:12 pm
by cambo3d
that' doesn't look stripped at all from what i can see...
Posted: Sun May 19, 2013 7:21 am
Bet there wasn't much grease in there from the factory. Be sure to pack it good with white grease.
I have several of those and each one came new with barely any grease. Those are good little motors
if you keep them cool with the fan and plenty of grease. Good luck with them.
Posted: Sun May 19, 2013 7:54 am
by foshon
I agree Cambo3d, there was absolutely no signs of anything being worn at all. That leaves me guessing as to why it wouldn't extrude. I think I possibly had my current set to low. I know I could have added more current as there was no sign of even a little heat when it was running. I think this little fella is going to go on junior.
Carl, it had grease in it. just enough to cover the gears, barely. I ended up using a fluoropolymer lube I had sitting around. Did all the research I could stand into if it would react with delrin, couldn't find anything.
Posted: Sun May 19, 2013 8:12 am
The grease you used should be fine. I agree on the current settings, these motors normally run hot, that's why
you must run the fan. Good luck with it Neil.
Posted: Sat May 25, 2013 12:37 pm
by foshon
I wanted a way to purge and clean my nozzle automatically. So I made a thing. It attaches to one of the upright extrusions at bed level (I chose "Z"). It is in two pieces so I can pull the part that interferes with printable area off. The code I use (in theory, haven’t used it yet waiting for hardware) will drop the nozzle into the cup purge 3mm and then wiggle "X" back and forth. I'll probably repeat the process a couple times to be sure.
I foresee the benefit being twofold; one, no more grabbing strings of filament and making a mess, two, the purge takes place about 46mm over and 115mm away from the center of the bed.
It is now here. http://www.thingiverse.com/thing:93820
[img]http://farm9.staticflickr.com/8394/8816550119_6e6a513a61_n.jpg[/img]
Untitled by foshon, on Flickr
[img]http://farm8.staticflickr.com/7396/8827156560_b4c8260e3c_n.jpg[/img]
Edit: added thing
Posted: Sat May 25, 2013 1:05 pm
Now that is a great idea! Good job!
Please share the code once you get it working.
Once again, a great idea!
Posted: Sat May 25, 2013 3:27 pm
by cambo3d
after awhile you probably would still have to clean the brush.. kool idea though
Posted: Sat May 25, 2013 4:53 pm
by ApacheXMD
foshon wrote:I wanted a way to purge and clean my nozzle automatically...
Man that is brilliant!
Posted: Sat May 25, 2013 5:43 pm
by Flateric
be less burned fingertips thats for sure.
Posted: Sat May 25, 2013 6:07 pm
Hey Neal, is that brush part of the Dremel collection?
Posted: Sat May 25, 2013 9:25 pm
by foshon
Eaglezsoar wrote:Hey Neal, is that brush part of the Dremel collection?
Thanks all.
Sam, it just pulls out of the block, switching it out would be fairly easy, I hope.
Carl, I have no idea. It came in a large multi-piece kit I bought off ebay last year. The shaft is 3.16mm so 1/8th ish. I think that is standard Dremel chuck size.
Posted: Sun May 26, 2013 1:08 am
by ApacheXMD
What might work well is brass wool used to clean soldering irons. I bet jiggling the nozzle in this would leave it glistening
http://www.newark.com/xytronic/459/sold ... dp/15J6972
Posted: Sun May 26, 2013 10:25 am
by jetpad
I like your brush idea. You could stick the gcode for it in the "prefix" for prints and it would always do that before it starts.
Posted: Sun May 26, 2013 1:53 pm
by foshon
Here is the code I put into the start of my prints. I use relative extruder measurements for Slic3r and this is set up for that. It homes, dives the nozzle into the center of the cup, starts heating the noozle and waits for it. Then, it extrudes 5mm wiggles, extrudes 5mm wiggles again, retracts 3mm and puts Y at zero.
G28 ; home all axes
G1 F6000 X3.30 Y115.0 Z45.60
M104 S205
M109
M83 ; use relative distances for extrusion
G1 F5040 E5.0000
G1 F1500 X-5.7
G1 F1500 X13.7
G1 F1500 X-5.7
G1 F1500 X13.7
G1 F1500 X3.3
G1 F5040 E5.000
G1 F1500 X-5.7
G1 F1500 X13.7
G1 F1500 X3.3
G1 F5040 E-3.000
G1 Y0
G92 E0
Posted: Sun May 26, 2013 3:18 pm
by Flateric
I'm curious why your running with relative distance/gcode setup rather than the standard 5D Absolute the majority of us run?
Some unknown advantage? Are you used to it from a previous piece of machinery?
Posted: Sun May 26, 2013 7:46 pm
by foshon
Flateric wrote:I'm curious why your running with relative distance/gcode setup rather than the standard 5D Absolute the majority of us run?
Well it started out as frustration when I would purge the nozzle manually only to watch the printer suck the filament out of the hot end at the start of the print. I also can't quite get my head around what happens when filament slips in absolute mode. If it slips on a retract for example, then it tries to rebuild pressure thinking that Xmm of filament isn't there, wouldn't it be prone to grinding the filament. No real reason I suppose, habit and making things like the code above easier.
Posted: Sun May 26, 2013 8:18 pm
by foshon
Here is a vid of the process.
http://youtu.be/ySk3zggE3Dw
Posted: Tue Dec 03, 2013 8:00 pm
by foshon
A note on the micro extruder unit. I have it mounted on junior now, running like a dream. I have been a Wade's/Budda fanboy for so long, I am stunned at the clean lines of the Pg/j-head combo on there now.
Posted: Tue Dec 03, 2013 8:12 pm
foshon wrote:A note on the micro extruder unit. I have it mounted on junior now, running like a dream. I have been a Wade's/Budda fanboy for so long, I am stunned at the clean lines of the Pg/j-head combo on there now.
Can you give us a pic of it mounted?
No problems with the additional weight?
