Page 4 of 4
Re: L-Cheapo Laser
Posted: Tue Oct 21, 2014 10:54 am
by Randavian
Everything has gone quiet here. Work, a short hospital stay, and Halloween preparations have delayed me from playing with my laser so far. Has anyone else done anything interesting with theirs?
Re: L-Cheapo Laser
Posted: Tue Oct 21, 2014 11:07 am
by heathenx
I was just screwing around with this yesterday. This time around I cut the parts with Repetier/Slic3r instead of using Inkscape. The box is kind of useless for me so it was nothing more than a test. I think it was 1/8" balsa.
Re: L-Cheapo Laser
Posted: Tue Oct 21, 2014 2:46 pm
by Randavian
That's an interesting construction design. Although I am sure that I will be cutting some things from time to time, I mainly purchased mine with engraving in mind. But I enjoy seeing all the things that people are doing with this laser.
Re: L-Cheapo Laser
Posted: Tue Oct 21, 2014 2:57 pm
by heathenx
Here's another example that I cut just a few minutes ago. Playing around with t-slot joints...on a miniature level.
Re: L-Cheapo Laser
Posted: Tue Oct 21, 2014 4:36 pm
by Randavian
That's cool. Got plans on building something, or just seeing what you can accomplish?
Re: L-Cheapo Laser
Posted: Tue Oct 21, 2014 4:52 pm
by heathenx
Just screwing around.
Re: L-Cheapo Laser
Posted: Thu Jun 25, 2015 1:14 pm
by mlapaglia
Received my L'Cheapo laser a few days ago and have had a chance to use it a few times. Shipping was lightning fast from 3D Supply Source.
I was disappointed that for $200 it had through hole components. The laser itself is press fitted into a heatsink not designed for this purpose. You can see where a hastily drilled hole still has metal shavings coming out of it.
[img]
https://mattlapaglia.com/wp-content/upl ... 24x760.jpg[/img]
The printed mount it came on is absolutely terrible. It looks like it was printed way too fast, one of the corners lifted off the bed during printing also.
[img]
The whole thing is held together with zip ties...
[img]
The laser focus ring wobbles inside of the laser casing. The silver ring can come off of the threads causing it to not rotate the actual focusing element. The fan cannot be controlled separately from the laser. When power is applied to the laser the fan comes on. It gets annoying to listen to the fan turning on and off during a print as the laser moves around the bed.
[img]
None of the mounting holes are usable. The portion of the printed part that the laser heat sink slides into was affected by the lifted print. The piece was cut with a knife to get the laser heat sink pushed into place.
[img]
The laser comes with some cheap chinese goggles. The ear pieces are adjustable and they seem to do the job though, I haven't gone blind yet.
[img]
After some tweaking of the focus ring and bed height I was able to get some decent results:
[img]
The build quality of the laser is atrocious given the price and how much the project raised on indiegogo. Overall I would not purchase this again and would dissuade other potential customers. Save some more cash and get a more powerful better constructed laser.
Re: L-Cheapo Laser
Posted: Thu Jun 25, 2015 6:18 pm
by jesse
There are some better quality ones sold at
http://jtechphotonics.com/
Re: L-Cheapo Laser
Posted: Thu Jun 25, 2015 6:20 pm
by Tincho85
What would be a good laser cutter/engraver for our printer?
The Laser-Bot from J-tech?
http://jtechphotonics.com/?page_id=333
EDIT: you beat me
Re: L-Cheapo Laser
Posted: Thu Jun 25, 2015 6:41 pm
by Tincho85
What I don't like of the Laser-Bot is that the driver board is a product apart, unlike the L-Cheapo.
Re: L-Cheapo Laser
Posted: Fri Jun 26, 2015 1:26 am
by stonewater
guess they call it el cheapo for a reason!
Tom C
Re: L-Cheapo Laser
Posted: Mon Nov 23, 2015 2:20 pm
by LdyMox
How is this working for people over time? I have ordered the L-Cheapo v3 (AKA 3.5 Watt) for my 3D printer. Techincally an x-mas gift for me and is on the way. I plan to build an enclourse for my unit so I don't risk anyones eyes.
What colors of acrylic have people had success in cutting? It seems that clear acrylic is likely a no go and opaque should be good, but there is a lot of middle grounds of Transparents/Translucents in all sorts of variations and colors. I can tell by this thread that red cuts well, but I am wondering if anyone had tried any others.
I am here because this is the most detailed user comments I have found on the L-Cheapo.
Re: L-Cheapo Laser
Posted: Mon Nov 23, 2015 3:28 pm
by Xenocrates
Clear acyrlic cuts reasonablely with IR lasers, such as CO2 lasers. The L-cheapo is a 445Nm laser however. At 445, the absorption of acrylic falls off a cliff. So you may not get a whole lot. Red would in theory be the best color to cut, as it will absorb the most energy, other than black (445Nm is basically blueish)
Re: L-Cheapo Laser
Posted: Mon Nov 23, 2015 8:56 pm
by Tincho85
Re: L-Cheapo Laser
Posted: Tue Nov 24, 2015 8:38 am
by LdyMox
Has anyone been able to engrave greayscale images with the L-Cheapo laser? Or are only simple images possible?
Re: L-Cheapo Laser
Posted: Tue Nov 24, 2015 10:15 pm
by LdyMox
More so did anyone figure out what the instructions meant by "change Z scaling to -1" in Slic3r..I can't find that setting anywhere.
I tried the laser plugin for Inkscape but it just crashed sadly
