Page 4 of 4
Re: Aurora's Rostock Max v2 build
Posted: Mon Oct 06, 2014 8:25 pm
by Aurora900
Okay, its done so here's the results: It seems it just really hates those overhangs. Is there any way to compensate for that?
[img]
http://staticexperiment.com/rostock/DSCN0233.jpg[/img]
[img]
http://staticexperiment.com/rostock/DSCN0236.jpg[/img]
[img]
http://staticexperiment.com/rostock/DSCN0237.jpg[/img]
[img]
http://staticexperiment.com/rostock/DSCN0238.jpg[/img]
Not bad overall I guess, but I wish the overhangs were better...
Posted: Tue Oct 07, 2014 12:02 am
by crocky
I'm just printing one now as well.
I am using kisslicer (reg) and it is building some support structure?
Be interesting to see how it goes, it is definitely a lot quieter than the da vinci and it looks real nice
How long did it take to print, this is going take about and hour?
Posted: Tue Oct 07, 2014 12:15 am
by Aurora900
crocky wrote:I'm just printing one now as well.
Took an hour and a half in repeteir
I also did the layer fan and now i'm printing something small just for fun because I have time before bed and why not
Posted: Tue Oct 07, 2014 12:22 am
by crocky
My test print will be the treefrog.... The da vinci prints them but not very well.
One hour is not too bad then, I don't like the slicer that it uses so mine is imported to repetier as g-code after I slice in kisslicer.
Posted: Tue Oct 07, 2014 12:31 am
by bot
To be frank, those are very excellent first prints. With my home built rostocks, it took weeks of tweaking to get it to the point you're at now.
Also... I thought I was ballin' with my three pack of disappearing purple. I see you've outdone me this time.
Posted: Tue Oct 07, 2014 12:50 am
by Aurora900
bot wrote:To be frank, those are very excellent first prints. With my home built rostocks, it took weeks of tweaking to get it to the point you're at now.
The 6 pack was like $5 or so at office max... I don't know if I could have gotten it cheaper (im sure its like half that on amazon lol) but its across from where I work so I just grabbed it on my lunch break. I could have gotten a simlar sounding product from avery... it was like 10 for the same price but something about that didn't sit right with me so I grabbed the elmers.
I'm sure to be using tons of this stuff... so I figured I might as well buy in bulk. Especially since it will be not only my boyfriend and I, but his two roommates as well will probably want to print stuff. Of course, no one is allowed to touch my machine but me and my boyfriend. Otherwise I'll cut their hands off... (on the plus side i can print them new bionic hands with the printer)
Posted: Tue Oct 07, 2014 1:07 am
by Aurora900
Here's what I just did for fun.... needs some tweaking, you don't even want to see the bottom... the person who made it didn't give any tips for the settings that should be used...
[img]
http://staticexperiment.com/rostock/DSCN0239s.jpg[/img]
This had to be done... if you recall what I named the printer and why, and if you know what this item is... it will all make sense
Posted: Tue Oct 07, 2014 3:57 am
by bot
Is it some kinda android CPU? (haven't seen any SG-1 for decades...)
Posted: Tue Oct 07, 2014 9:19 am
by Aurora900
bot wrote:Is it some kinda android CPU? (haven't seen any SG-1 for decades...)
It's a replicator block, its what the replicators are made of
Posted: Tue Oct 07, 2014 10:50 am
by nitewatchman
Aurora900 wrote:bot wrote:To be frank, those are very excellent first prints. With my home built rostocks, it took weeks of tweaking to get it to the point you're at now.
Best thing I did for print quality and lower stress levels was to add a heat spreader plate and start printing on PEI. An easy modification and not terribly expensive.
No more gluing, spraying, taping, cleaning, scraping, cussing, throwing curled printed stuff, etc.
I bought a jumbo pack of Elmer's glue, enough to last Mrs. Clark's kindergarten class for a couple of weeks and ended up using 2 of the 24 tubes.
nitewatchman
Posted: Tue Oct 07, 2014 12:48 pm
by Aurora900
nitewatchman wrote:Aurora900 wrote:bot wrote:To be frank, those are very excellent first prints. With my home built rostocks, it took weeks of tweaking to get it to the point you're at now.
nitewatchman
I might have to look into that for a future upgrade, thanks
Posted: Tue Oct 07, 2014 5:10 pm
by bot
Nitewatchman, is the heat spreader Aluminum? How thick? Did you adhere the PEI to the alu?
Posted: Tue Oct 07, 2014 7:43 pm
by barry99705
You should print up one, then make a plaque for your printer that says, "For the person who touches my printer".
Posted: Tue Oct 07, 2014 10:26 pm
by Aurora900
barry99705 wrote:Aurora900 wrote:bot wrote:To be frank, those are very excellent first prints. With my home built rostocks, it took weeks of tweaking to get it to the point you're at now.
I like the way you think
Posted: Tue Oct 07, 2014 10:59 pm
by nitewatchman
bot wrote:Nitewatchman, is the heat spreader Aluminum? How thick? Did you adhere the PEI to the alu?
My heat spreader is copper, many people successfully use aluminum. I chose copper because its heat transfer rate is significantly higher BUT so is the cost. I think that either will work.
I attached the PEI to the Glass Build Plate with 12" wide 3m tape and stack the entire assembly and hold in place with pinch clamps. Down side is that the temperature variance between the top surface and the bed thermistor in the stackup is 5 or so degrees until the system is thourghly soaked.
Posted: Tue Oct 07, 2014 11:12 pm
by Aurora900
nitewatchman wrote:bot wrote:Nitewatchman, is the heat spreader Aluminum? How thick? Did you adhere the PEI to the alu?
I have ton of copper foil laying around, but its probably way too thin... I assume you'd need something thicker/more rigid
Posted: Wed Oct 08, 2014 8:08 am
by nitewatchman
While anything could help, I used a 1/16" sheet. I also wanted the stored thermal mass.
