Lift Between Towers X & Y
Posted: Sat Mar 12, 2016 10:48 am
by Sakey
Just sorting out the calibrations on my Rostock MAX v2 . Towers seem to level nicely when calibrating but when I am printing the level aid as a test the print nozzle end up a good couple of mm away from the bed mid way between X & Y Tower . Just wondering if there are any potential fixes.
I have calibrated multiple times to try and solve this but each time I get the same result. The rest of the print is fine BTW other than the lines between X & Y.
Re: Lift Between Towers X & Y
Posted: Sat Mar 12, 2016 3:38 pm
Did you do the complete calibration as it says to do in the build manual?
A lot of the calibration is dependent on doing the calibration in an exact order and in same sequence as written.The newest manual is under the downloads
folder at the Seemecnc.com site. Make sure you have the latest one. Come back to us and let us know that you are using the
latest manual and are doing the calibration as exactly indicated by the build manual.
Posted: Sun Mar 13, 2016 9:16 am
by Sakey
I followed the "Version 1.25, February 17th, 2016" if that is the latest one? Leveled the bed with both the first method stated and the alternative method stated near the end (the one using feeler gauges). It was the first thing I did was go back and follow it precisely when getting problems to make sure I wasn't doing something stupid.
