				Concentric layer fan shroud
				Posted: Fri Mar 18, 2016 5:53 pm
				by srgntforest
				hey everyone, I've had this up on thingiverse for a bit, and figured its would be good for the community. The design improves on the original, and removes the need for extra layer fans.
http://www.thingiverse.com/thing:1377757
				Re: Concentric layer fan shroud
				Posted: Fri Mar 18, 2016 6:36 pm
				by BTP
				Nice design I may give this one a go.
				Posted: Mon Apr 04, 2016 6:00 pm
				by Neptune
				I printed this design, I really like it but with my e3d v6 it is too close to the heater block and it started to droop/melt.  I even printed it in ABS....may have to try it in Nylon or something higher temp...
				Posted: Fri Apr 15, 2016 3:34 pm
				by Saber
				Neptune wrote:I printed this design, I really like it but with my e3d v6 it is too close to the heater block and it started to droop/melt.  I even printed it in ABS....may have to try it in Nylon or something higher temp...
You could try putting a small layer of aluminum foil or something on top of it as a heat reflector, or maybe just make it wider diameter so it's not quite as close.
				Posted: Fri Apr 15, 2016 3:40 pm
				by Xenocrates
				Let's see, Protopasta has HT-PLA which when annealed should reject more heat.  You could also use duct tape (Not duck, but the aluminized stuff) to cover the top surface.  Personally, I like the Berd air as a concept (But I still have to nail down a good mount for it), as it's all aluminum.
				Posted: Mon Apr 18, 2016 12:06 pm
				by Neptune
				Xenocrates wrote:Let's see, Protopasta has HT-PLA which when annealed should reject more heat.  You could also use duct tape (Not duck, but the aluminized stuff) to cover the top surface.  Personally, I like the Berd air as a concept (But I still have to nail down a good mount for it), as it's all aluminum.
I like the idea also, but just don't like the external pump bit...
